no pressure in clutch pedal HELP!!
Old Mar 21, 2005 | 04:43 PM
draygenx's Avatar
Default no pressure in clutch pedal HELP!!
I have a 92' S, The clutch master went bad on me and I have replaced it and the slave but I'm still having issues getting pressure. The whole hyro clutch system is a new thing to me but I assume it's the same as a brake system. Bleed until the air is gone and boom, done. I bleed off the the slave until there was no air left but there's still not enough pressure to release the clutch, just enough to return the pedal to the starting position. Any suggestions would be great!!!!
Old Mar 21, 2005 | 04:46 PM
Greyout's Avatar
Default Re: no pressure in clutch pedal HELP!! (draygenx)
I would suggest making SURE you're bleeding it properly. You've probably got air up at the MC end.
- loosen bleeder valve
- depress pedal to floor & leave it there
- tighten bleader valve
- add fluid if needed
- pull pedal back up w/ hand
repeat MANY times... especially if you are having a hard time (there may be air way up in the line). If you end up using a lot of brake fluid, so be it.
Old Mar 21, 2005 | 05:04 PM
draygenx's Avatar
Default Re: no pressure in clutch pedal HELP!! (Greyout)
i thought that might be it but there's no bleed valve. how should i be going about removing any air in the mc?
Old Mar 21, 2005 | 06:15 PM
AndyD's Avatar
It takes a lot of pumping to bleed the clutch system. It took me a good 15 minutes to finally get pressure again.
Old Mar 21, 2005 | 06:28 PM
BillClinton's Avatar
Make sure your slave is good. Pull the boot back and inspect for leakage. If there is any replace it. Let the system gravity bleed for a while. then have someone help you bleed it:
-Pedal to floor,bleeder open, reservoir full (Make sure you fill reservoir and not just the rubber boot inside reservoir)
-5-10 min.
-Close bleeder
-go in car, pump pedal to floor and all the way back up 5-6 times
-Hold down, have assistant crack bleeder
-Be sure reservoir is full
-Repeat until good pedal and no air comes out
DO NOT SHAKE FLUID-will form air bubbles
Old Mar 21, 2005 | 09:21 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draygenx &raquo;</TD></TR><TR><TD CLASS="quote">i thought that might be it but there's no bleed valve. how should i be going about removing any air in the mc?</TD></TR></TABLE>
bench bleed it thru the lines
r1de4life
Jan 16, 2006 10:06 AM
ichiban_719
Nov 30, 2005 04:31 AM
illusion
Jul 31, 2005 09:50 AM
lude97dude
May 23, 2003 04:42 AM
PSU-TEG
Dec 3, 2002 08:14 AM
