Best Coil-Over / Drop Spring set up
Old Jan 24, 2002 | 07:39 PM
suprafly20's Avatar
New User
Default Best Coil-Over / Drop Spring set up
What would be the best set up for either coil-overs or drop springs for a '99 Integra GS-R? I have been looking at the Tein and the ApexI N1's but I dont know what the best set up would be......hit me up with some companies and ideas
- Jon -
Old Jan 24, 2002 | 08:04 PM
Ecto1's Avatar
New User
Default Re: Best Coil-Over / Drop Spring set up (suprafly20)
Mark one for the H&R Coilovers. A superb setup!
Also, well priced.
Old Jan 24, 2002 | 08:58 PM
mafay2's Avatar
New User
Default Re: Best Coil-Over / Drop Spring set up (Ecto1)
For spring/shock set up, i have to give to the Tein NA. Of course, I am using it myself!!
Old Jan 24, 2002 | 09:23 PM
threatcon13's Avatar
New User
Default Re: Best Coil-Over / Drop Spring set up (mafay2)
tein
Old Jan 25, 2002 | 03:46 AM
Neo's Avatar
Neo
Can't go wrong w/ H&Rs or Teins, they are great products but they are a bit pricey. Less expensive would be to get Ground Control coilovers with Koni yellows (single adjustables). You can get all that for about $850-900, plus you can custom order the spring rates for the GCs if you want.
Old Jan 25, 2002 | 08:12 AM
6SPD_EK's Avatar
how much loot do you have, and is this a street ot track car?
Mugen Lowdown (street) http://www.kingmotorsports.com
Mugen N1 (track)
Toda Fightex (external reservoir) http://www.todaracing.com/Fightex.html
these are in the $1500-2500 range (you did say best)
I think a couple of guys in the ITR forum have the lowdown setup - do a search, its in there. I am not sure if anyone is running the N1 or fightex
[Modified by 2000-4DRGSR, 9:12 AM 1/25/2002]
Old Jan 25, 2002 | 08:51 AM
pete-o's Avatar
New User
Do the H&R coilovers let you adjust the stiffness of the ride as well as the height? Like Koni yellows do? Just askin' because I'm looking at getting a coilover setup for my teg too.
Old Jan 25, 2002 | 09:06 AM
rockwilda's Avatar
Default Re: Best Coil-Over / Drop Spring set up (pete-o)
<-- ZEAL B2 lover
Old Jan 25, 2002 | 09:18 AM
Neo's Avatar
Neo
All coilovers mentioned here have "threaded" bodies which allow you to customize the drop/ride height. I don't know if H&Rs have adjustable damping on their shocks. Even if they do, keep in mind that ideally shocks should be "tuned" to a particular spring rate, such that it is not over- or under-damping the bounce from the spring. If the H&Rs are not adjustable, I'd be willing to bet that the shocks are tuned to the spring, as most high quality coilovers do this.
Old Jan 25, 2002 | 09:36 AM
milano's Avatar
Default Re: Best Coil-Over / Drop Spring set up (Neo)
H&R COIL OVERS!
Old Jan 25, 2002 | 10:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Best Coil-Over / Drop Spring set up (2000-4DRGSR)
Mugen N1 (track)
Ha, you want expensive, try Mugen's Moton remote-reservoir double adjustable threaded body shocks (whew, say that 5 times fast! ).
You too can have a set of these for the low low price of just $1199.95 per CORNER (4 required per car, obviously).
FIFA RACING
Feb 22, 2010 01:03 PM
sr_teggy
Mar 14, 2008 06:22 AM
Takashi1978
Jun 7, 2004 08:46 PM
ILOVEGIRLS
Nov 22, 2001 11:13 AM
integra2000
Sep 25, 2001 10:37 AM
