Is my clutch master/slave cylinder going out?
Old Mar 21, 2005 | 03:45 PM
djtsmith007's Avatar
Default Is my clutch master/slave cylinder going out?
How do you tell if your clutch master or slave cylinder is going out? I ask because i thought my clutch was going out, it was sorta sputtering in high gear low rpm, so i had it replaced with a exedy racing clutch. And now it doesn;t do it as much but it still does it. What does everyone think?
Old Mar 21, 2005 | 04:59 PM
hondandy's Avatar
Default Re: Is my clutch master/slave cylinder going out? (djtsmith007)
seems it would do the opposite (sputter in low gear high rpm)
if the cylinder was going it would only effect shifting not after you were in gear
Old Mar 21, 2005 | 07:02 PM
Default Re: Is my clutch master/slave cylinder going out? (hondandy)
Ok, so what would my problem be then if it is not the master clutch cylinder?
Civicfanatic_09
Jan 20, 2010 08:58 PM
vietdragontekx
Jan 29, 2008 03:00 PM
johnqt3
Oct 7, 2005 11:05 AM
Lei Siew Long
Oct 22, 2002 10:43 AM
