h22 stage 2 cams????? need info please
Old Mar 21, 2005 | 02:46 PM
7speed's Avatar
Default h22 stage 2 cams????? need info please
im looking for a little more power. Im looking into stage 2 cams they say i can get 15 to 20 more wheel power. is it the next step to get the time i want? i want know what your guys think of cams. And how does it really work
Old Mar 26, 2005 | 07:46 AM
rival12's Avatar
Default Re: h22 stage 2 cams????? need info please (7speed)
Cams set the amount of duration and lift for the valves, 2 camshafts, one for intake and one for exaust. It sets the amount of fuel and air coming in.
Old Mar 26, 2005 | 10:27 PM
Nick H's Avatar
New User
Default Re: h22 stage 2 cams????? need info please (rival12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rival12 &raquo;</TD></TR><TR><TD CLASS="quote">It sets the amount of fuel and air coming in.</TD></TR></TABLE>
actually, a camshaft doesn't have to do with the amount of air coming in...a particular displacement must be filled everytime the piston is on its intake stroke...the same amount of displacement is always filled with the same amount of air/fuel (unless you get into forced induction)...performance cams actually control the efficiency of the flow of air/fuel coming into the combustion chamber by allowing the valves to stay open both further and longer...and the more efficiently your engine's airflow is, the more power you have...
Old Mar 26, 2005 | 10:33 PM
Intense3.2's Avatar
Default Re: h22 stage 2 cams????? need info please (Nick H)
just remember your not only gonna have to buy cams... good luck.
Old Mar 27, 2005 | 08:43 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7speed &raquo;</TD></TR><TR><TD CLASS="quote">im looking for a little more power. Im looking into stage 2 cams they say i can get 15 to 20 more wheel power.</TD></TR></TABLE>
Stage 2 what?
Regardless, You will need fpr, 190 pump, better valvetrain and bump in CR if you want to make use of the whole powerband, and lots of tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7speed &raquo;</TD></TR><TR><TD CLASS="quote"> i want know what your guys think of cams. </TD></TR></TABLE>
Seeing as how I can't imagine my motor running without them, I guess I like cams.
Old Mar 27, 2005 | 12:35 PM
v4lu3s's Avatar
RTFM
the stock accord pump will support 250 hp easily so i wouldnt waste money on a pump and fpr unless the stock parts have failed. the tuning and valve train are a must to get good power and more compression never hurts with cams.
Old Mar 27, 2005 | 12:50 PM
SuperSlow's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the stock accord pump will support 250 hp easily so i wouldnt waste money on a pump and fpr unless the stock parts have failed. the tuning and valve train are a must to get good power and more compression never hurts with cams.</TD></TR></TABLE>
Are you saying that you are running an H22 on profiles similar to S2S2 cams in your accord with non-adjustable FPR and your stock pump?
That is rare. What are you using to tune it?
adam00
Aug 13, 2008 05:24 AM
ghostofnyc
12
Jan 27, 2006 02:17 PM
Ludeguy2486
Jan 24, 2006 04:36 AM
dayne808
Jul 28, 2005 09:00 PM
Sprayin_civic
May 2, 2005 01:00 AM
