Why did the headlight suddenly fog up?
Old Jan 24, 2002 | 07:20 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Why did the headlight suddenly fog up?
I don't get this. I've had my car for over 8 months now and I've never had any problems with the headlights. Now just last week, I suddenly get massive condensation inside BOTH driver side lenses. I could probably use a hairdryer to dry out the high beam lens, but on the projector lens, it's behind the outer plastic cover, so the projector lens would block a hairdryer being able to dry off the inside of the cover. Am I just going to have to remove the plastic cover to dry it? And what in the heck could cause this problem to pop up so suddenly?
Just so you know, I've never had a headlight explode in the housing, I've never had the headlights apart or anything, and I've had the 9005 conversion for over 6 months now, and no problems until just last week. Any ideas?
[Modified by PatrickGSR94, 10:21 PM 1/24/2002]
Old Jan 24, 2002 | 07:47 PM
strils's Avatar
Default Re: Why did the headlight suddenly fog up? (PatrickGSR94)
maybe a rock flew up and put enough of a crack/hole to let moisture in but is hard to see
Old Jan 24, 2002 | 08:01 PM
Duck Sauce's Avatar
Default Re: Why did the headlight suddenly fog up? (strils)
Take it to the dealership, and have them seal it.
Old Jan 24, 2002 | 09:49 PM
Disco Monkey's Avatar
i had a leak in my headlight so i pulled the headlight housing out of the car and took a water hose and put in one hole and plugged the other hole. the housing filled up with water until it had to come out of the place where it was leaking. it was leaking where the clear plastic meets the grey plastic on the top of the housing...i guess the seal was broken. so i put some silicone there and let the headlight dry out. no problems now.
Old Feb 4, 2002 | 08:41 AM
Rtzx9r's Avatar
GDD 1%
Default Re: Why did the headlight suddenly fog up? (Disco Monkey)
I have a 98. My driver side did this about 8 months ago. Warranty repair. I put in the 9005 conversion, doubling up the o-rings. Now, 6 months after the 9005 install, the pass sie is all fogged up. Warranty time again!!
Old Feb 4, 2002 | 11:19 AM
Community Builder
Default Re: Why did the headlight suddenly fog up? (Rtzx9r)
You better put stock 9006 back in before taking it in for warranty repair. And please, if you can, find out from the dealer what caused the passenger side lights to fog up.
Old Feb 4, 2002 | 12:18 PM
FourDoorGSR's Avatar
Didnt it leave water spots inside the housing after you filled it with water and dry out?
Old Feb 4, 2002 | 02:30 PM
Vtec195hpR's Avatar
Default Re: Why did the headlight suddenly fog up? (FourDoorGSR)
one reason that the headlamps keep fogging up is that you have taken the light bulbs out too many times. I remember the first time when I took mine out, it was a really tight. after messing with them with aftermarket bulbs, the fitting became loose, not as tight when you turn them to click. that may be the reason if there's no holes or cracks in the lights housings.
Old Feb 4, 2002 | 03:48 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Why did the headlight suddenly fog up? (Vtec195hpR)
humm, so am I seeing a trend with the 9005 conversion? hummmmm
maybe it's good i never did this....
Old Feb 4, 2002 | 05:25 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Why did the headlight suddenly fog up? (Pb_Foot)
No, actually mine did this before I did the conversion. (well, one did) The acura dealerships I go to (2 of them) both stock these headlamps, so I can think it is a common thing. I think there is a bad design problem because I have never seen/heard of other car's lights doing this, and these are no different.
(oh yeah, for sure I will put in the stock bulbs before taking it in!!!- thanks though)
Old Feb 5, 2002 | 05:52 AM
Community Builder
I had my 9005 conversion for over 6 months before this happened. And when I want to show someone the difference between 9005 and stock, I always take the passenger side light out to put a stock bulb back in, but it's my driver side light that's fogging up.
vodkaTM
Feb 5, 2009 01:55 PM
et-s-m-c
Jul 18, 2008 06:41 PM
I Like Hondas
Jul 5, 2006 11:16 AM
rota power
Jun 17, 2006 06:02 PM
Nick DC
Jul 22, 2005 12:44 PM
