Another rear disc conversion ? and not about the parts needed.
Old Mar 21, 2005 | 01:24 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Another rear disc conversion ? and not about the parts needed.
I have searched and I already have a spare set of trailing arms from a 91 Integra, but someone told me I could use CRX Si trailing arms and the setup would work. They told me the Integra trailing arm will make the rear track of my EF slightly wider, and that if I wanted to keep the same rear track I should use the CRX trailing arms. Can someone confirm this for me? Thanks for any replys I get back.
Old Mar 21, 2005 | 02:46 PM
vtecn8ive's Avatar
Default Re: Another rear disc conversion ? and not about the parts needed. (JDMThoughts)
I would say no. They shoudl be abel to swap onto the Integra trailing arm but should not be needed.
Old Mar 21, 2005 | 03:02 PM
DocSean's Avatar
My understanding is that you can use the DA trailing arms, but just not the compensator arms.
Old Mar 21, 2005 | 03:08 PM
kid-honda's Avatar
Default Re: (spankjelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">My understanding is that you can use the DA trailing arms, but just not the compensator arms.</TD></TR></TABLE>
The DA trailing arm is exactly the same, I have compared them side by side.
Old Mar 21, 2005 | 03:21 PM
stickershop.ca's Avatar
Default Re: (kid-honda)
With the exception of the trailing arm bushing size, they are the same. I believe the Integra arms have a slightly larger trailing arm bushing.
Old Mar 21, 2005 | 03:41 PM
eda6's Avatar
Default Re: (stickershop.ca)
As mentioned above, you can use either trailing arm. Use your existing control arms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickershop.ca &raquo;</TD></TR><TR><TD CLASS="quote">I believe the Integra arms have a slightly larger trailing arm bushing.</TD></TR></TABLE>
Only DA trailing arms have the larger ta bushing.
d16trexin
Dec 31, 2008 11:00 PM
serb_rida
Suspension & Brakes
Jun 19, 2008 04:16 PM
ED9man
21
Jun 7, 2006 05:07 PM
fraknstien
May 12, 2006 04:08 PM
cliff666
Jun 20, 2005 03:08 PM
