Problems with the way my Accord is running!
Old Mar 21, 2005 | 11:57 AM
jipr's Avatar
Default Problems with the way my Accord is running!
Two weeks ago I refueled my '92 Accord EX (it has 121k miles). I drove 1/4 mile or so and while accelerating the car was hestitated, lost acceleration power and stalled. I had it towed to my mechanic. He replaced the distributor and it ran well for a day. It exhibited the same problem minus the stalling out. I took it back and the fuel filter was replaced (last replacement was at 82k miles). It still is exhibiting the same problem only worse now. I replaced the air filter becuase it was filthy. The timing chain was also replaced at 82k miles. Could it be the timing chain, fuel line, fuel pump, tranny? Any clues? Thanks.
Old Mar 21, 2005 | 12:27 PM
Desslok's Avatar
Default Re: Problems with the way my Accord is running! (jipr)
This happened right after refueling? Could be bad gas or diesel.
Old Mar 21, 2005 | 12:36 PM
ACC0RD22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jipr &raquo;</TD></TR><TR><TD CLASS="quote">Two weeks ago I refueled my '92 Accord EX (it has 121k miles). I drove 1/4 mile or so and while accelerating the car was hestitated, lost acceleration power and stalled. I had it towed to my mechanic. He replaced the distributor and it ran well for a day. It exhibited the same problem minus the stalling out. I took it back and the fuel filter was replaced (last replacement was at 82k miles). It still is exhibiting the same problem only worse now. I replaced the air filter becuase it was filthy. The timing chain was also replaced at 82k miles. Could it be the timing chain, fuel line, fuel pump, tranny? Any clues? Thanks. </TD></TR></TABLE>
eerrrrr timing chain??? do you mean belt?
try replacing your plugs/wires/dizzy
Old Mar 21, 2005 | 12:42 PM
philadd's Avatar
Default Re: Problems with the way my Accord is running! (ACC0RD22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACC0RD22 &raquo;</TD></TR><TR><TD CLASS="quote">
try replacing your plugs/wires/dizzy</TD></TR></TABLE>
he already stated that the distributor was replaced...
Old Mar 21, 2005 | 01:09 PM
honda_kid42's Avatar
i would get new plugs and wires....had the same problem last month with my winter car...it would accelerate very sluggish and always felt like it was going to stall....nothing looked bad but i figured i would just change the plugs and wires and it took car of the problem....
Old Mar 23, 2005 | 06:03 PM
jipr's Avatar
Default Re: Problems with the way my Accord is running! (philadd)
Hi Phil, I'm still having the same problem - hesitation when accelerating from stop to abot 20 - 30 mph. After that it's fine. As I stated on my original post, I had the distributor and fuel filter replaced. I changed the air filter and the plugs. I'm reading thru my Haynes Auto Repair book and see in the troubleshooting section: Engine stumbles on acceleration. Any clues what exactly that might mean? For this symptom they say causes could be: fouled plugs (replaced them), fuel injector system faulty, fuel filter clogged (relaced it but will check for new dirt/clog), incorrect ignition timing, intake manifold air leak. What's your opinion.
Old Mar 23, 2005 | 06:06 PM
-RedneckDave-'s Avatar
Working
If it happened right after fueling your car then It is most likely bad gas. Put some fuel system treatment in and it should take care of the problem.
Old Mar 23, 2005 | 07:03 PM
daveedd357's Avatar
sounds like you have plugged egr ports. it costs 180 to get them cleaned and unplugged the right way.
Old Mar 23, 2005 | 08:22 PM
as_fast_as_u's Avatar
how is ur catalytic converter? if it is plugged its going to run like ****, stall at low rpm and stop and go driving... but at higher rpm it seems to do fine
Old Mar 24, 2005 | 07:55 AM
jipr's Avatar
Default Re: (gude_f23a1)
how do i check if the catalytic converter is plugged. the car doesn't stall but at times hesitates when accerlerating to 30mph or so. once it hits the higher speeds i'm fine.
ChevelleSSLS6
Jun 8, 2010 11:39 AM
87tpimonte
Aug 16, 2008 11:29 AM
89D15CRXDX
Jun 13, 2008 08:05 AM
Bear Down
Nov 21, 2005 08:16 PM
accord91lx
Jul 6, 2003 05:16 AM
