HELP!!! 91 si
Old Mar 21, 2005 | 09:56 AM
95_turbo's Avatar
Default HELP!!! 91 si
well here's my story...i have a 91 si hb and the problem i'm having is that i have to hold the ignition switch in the start (or III) to keep it running,if i let i got back to acc ( II) it will die...also in acc i'm not getting any dash lights or the clock to go on till i start it up... i cheked th fuses and everything it's fine ...could it be a relay or the switch???
Old Mar 21, 2005 | 11:14 AM
mahatma's Avatar
Default Re: HELP!!! 91 si (95_turbo)
Same thing happened to me just a couple weeks ago. Ignition switch, I'd put my life on it!!
Junkyards kept wanting to sell me the whole lock/tumbler assembly with it, but you only need the switch
Old Mar 21, 2005 | 02:51 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_turbo &raquo;</TD></TR><TR><TD CLASS="quote">well here's my story...i have a 91 si hb and the problem i'm having is that i have to hold the ignition switch in the start (or III) to keep it running,if i let i got back to acc ( II) it will die...also in acc i'm not getting any dash lights or the clock to go on till i start it up... i cheked th fuses and everything it's fine ...could it be a relay or the switch???</TD></TR></TABLE>
For sure, 100% electrical portion of the ignition switch.
<FONT COLOR="red">35130-SH5-505</FONT>, SWITCH, STEERING Courtesy of your local Honda parts dept...@50.00 or so...
puertoricanboy90
Mar 17, 2010 03:04 PM
csk239
Nov 14, 2009 04:54 PM
HondaEJ7
23
Jan 27, 2008 12:48 PM
sddefiant
Nov 24, 2006 04:37 PM
Acswitz
Dec 28, 2004 06:12 PM
