cam angle sensor question (ZC)
i am putting a OBD-1 DOHC ZC in my 91 hatch. my motor came in the other day and as i was looking it over i noticed that it didn't have the cam angle sensor on the exhaust cam, then i realized, duh it is built in the dizzy because it is OBD-1. my question is can i just run the factory cam angle sensor wires in my wiring harness to the cam angle sensor wires in the dizzy. or do i have to use the external sensor on the exhaust cam? i am still using OBD-0 ECU.
Ok so are you DX or HF/Si ?
Converted to MPFI already if DX?
What ECU are you using? (code please)
Take a pic of the distributor so i can identify it...
if you are running it OBD0 you will need the Cylinder Position Sensor (on end of exhaust camshaft) and distributor from 88-89 Integra D16A1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">if you are running it OBD0 you will need the Cylinder Position Sensor (on end of exhaust camshaft) and distributor from 88-89 Integra D16A1</TD></TR></TABLE>
But then will it still be OBD-1? Isn't the reason to go OBD-1 so you can have better tuning possibilities? - Darrell
twentyhurtz
May 21, 2009 06:17 AM
jtmoney2002
Aug 25, 2008 04:43 PM
N1cky
Feb 8, 2007 11:14 AM
thenick
10
Jan 6, 2007 08:29 AM
-[sphEre]-
13
Oct 14, 2004 08:08 PM
