Power steering leak on a '01
Old Mar 21, 2005 | 08:06 AM
matt_in_sd's Avatar
Default Power steering leak on a '01
My sister has an '01 thats leaking p/s fluid from the bellow at the end of the rack n pinion unit. Is this a simple seal that can be replaced without pulling the whole rack n pinion unit?
Old Mar 21, 2005 | 09:49 AM
Turbowa's Avatar
Default Re: Power steering leak on a '01 (matt_in_sd)
If it is infact leaking from there you will have to replace the whole rack. Hondas power steering racks are not servicable.
Old Mar 21, 2005 | 02:23 PM
matt_in_sd's Avatar
Default Re: Power steering leak on a '01 (Turbowa)
Any opinions on using additives like Lucas stop leak?
Old Mar 22, 2005 | 01:15 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_in_sd &raquo;</TD></TR><TR><TD CLASS="quote">Any opinions on using additives like Lucas stop leak? </TD></TR></TABLE>
Highly doubt those will work since it's the boot itself that is leaking NTM the actual seal. Mine is doing the same and it's a 90...shitty design luckily yours err hers may still be in warranty; at least it's worth a check.
Old Mar 22, 2005 | 07:54 AM
iam7head's Avatar
try to get her car in for the 40 point *Free inspection they have going on now
94DCTeg
Acura TSX
Sep 9, 2009 08:00 AM
rotascircuit
Sep 9, 2008 05:01 PM
94c1v1cex
May 21, 2007 05:03 PM
hungtat
Oct 19, 2006 12:33 PM
nek0
Sep 25, 2003 08:06 AM
