LOWERING TIRE PSI PROS AND CONS?
Old Mar 21, 2005 | 07:32 AM
EJtypeR's Avatar
Default LOWERING TIRE PSI PROS AND CONS?
im off to the track on the 26th. last time i was at the track my 60ft times blow. im running 16 rotas with yokahama parada spec 2 tires 205/45/16. what is the lowest air pressure i could run? and also would my trap speed be slower with less air? any input would help. thanks.
Old Mar 21, 2005 | 07:48 AM
serturbo's Avatar
Default Re: LOWERING TIRE PSI PROS AND CONS? (EJtypeR)
Although tire pressure does play a part in traction, driving skill is a greater factor. You need to modulate the gas and not just peg it to the floor board. I easily got 2.4 on 215-35-18 Spec-2's. Mind you, this was with no LSD. You should be able to get 2.2's or 2.3's on 16's with no problem. I would run tire pressure in the mid 20's. You don't want to run too low of a pressure or the center of the tire will bow in. Try playing with tire pressure at home in your driveway. Adjust tire pressure and run your car through a patch of water. Look at the contact patch after leaving the water. You'll know for sure if the tire is bowing.
Old Mar 21, 2005 | 09:14 AM
EJtypeR's Avatar
Default Re: LOWERING TIRE PSI PROS AND CONS? (serturbo)
alright cool thanks ill do that.
Old Mar 21, 2005 | 11:01 AM
EJtypeR's Avatar
anyone else?
Old Mar 21, 2005 | 11:13 AM
smokie's Avatar
good ****!!!
Old Mar 21, 2005 | 05:03 PM
1750cc's Avatar
Default Re: LOWERING TIRE PSI PROS AND CONS? (smokie)
i agree. mid to high 20s should be fine. if you can, go with 15's.
Old Mar 22, 2005 | 07:15 AM
EJtypeR's Avatar
Default Re: LOWERING TIRE PSI PROS AND CONS? (1600cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1600cc &raquo;</TD></TR><TR><TD CLASS="quote">i agree. mid to high 20s should be fine. if you can, go with 15's. </TD></TR></TABLE>
20 PSI W/ 15INCH wheels?or what i have my stock 14 inch steelies sitting in my garage with some pepboyz special tires on there.
Old Mar 22, 2005 | 08:02 AM
RaceProfessor's Avatar
I drove an identical car as yours, 97' DX coupe, ITR swap, I/H/E on 205 BFG drag radials and went 13.93 @ 97mph with a 2.1 60'. Lower tire pressure gives you more bite at the launch pad and reduces wheelhop but it also slightly reduces your trap speed and high gear stability. On street tires, I would do about an even 20psi. Buy some 215/60/14's BFG drag radials for those 14's wheels and you'll be good to go.
Sam
Old Mar 22, 2005 | 08:12 AM
dohcter g's Avatar
Default Re: LOWERING TIRE PSI PROS AND CONS? (RaceProfessor)
2.16 60ft with steelie 13's with cheap tires at 15 psi!
1.78 60ft with steelie 14's with MT 20x6x14 at 12 psi!
Old Mar 22, 2005 | 10:49 AM
EJtypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote">I drove an identical car as yours, 97' DX coupe, ITR swap, I/H/E on 205 BFG drag radials and went 13.93 @ 97mph with a 2.1 60'. Lower tire pressure gives you more bite at the launch pad and reduces wheelhop but it also slightly reduces your trap speed and high gear stability. On street tires, I would do about an even 20psi. Buy some 215/60/14's BFG drag radials for those 14's wheels and you'll be good to go.
Sam</TD></TR></TABLE>
im gonna try and get some slicks.
Twigster311
Aug 10, 2003 05:31 PM
PoonHunter
Jul 14, 2003 11:39 AM
bhang
Aug 8, 2002 05:48 AM
momo48
Jan 23, 2002 06:25 PM
skyline69
Jan 5, 2002 04:03 PM
