ef clutch and flywheel question
Old Mar 21, 2005 | 07:24 AM
99sonicbluegsr's Avatar
Default ef clutch and flywheel question
i am putting in a OBD-1 DOHC ZC in my 91 hatch, but my tranny is a 89 d-series tranny. it will work as long as i get a 90-91 flywheel and clutch correct?
Old Mar 21, 2005 | 09:27 AM
BlackCRX's Avatar
all d series 89+ flywheels and clutchs are the same
Old Mar 21, 2005 | 11:41 AM
ServiceAdvisor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX &raquo;</TD></TR><TR><TD CLASS="quote">all d series 89+ flywheels and clutchs are the same</TD></TR></TABLE>
Negatory, call PepBoys or Autozone ect. and ask for the part #s on the 89 and 90-91 flywheels, they are different. Match the flywheel and clutch to the trans year. - Darrell
Old Mar 21, 2005 | 11:54 AM
BlackCRX's Avatar
im running a y8 motor with a z6 tranny and im using a a6 clutch with a z6 flywheel
everything bolts up perfectly
Old Mar 21, 2005 | 12:15 PM
hatchblack's Avatar
Default Re: ef clutch and flywheel question (99sonicbluegsr)
89 is smaller, so if you are using an 89 flywheel, you need the clutch setup from an 89. 1990 and up are a little bigger, so you can use any clutch set from 90-00 o to match a flywheel from 90-00. i believe all d-series motors use the same flywheel and clutch set from those years. i have a 90 flywheel and clutch in my 89 hatch with my 89 transmission attached to my 93 z6 motor, so it will all bolt up. just make sure, like i said, to get a 90-00 clutch/flywheel combo, or stick with 89 clutch/flywheel setup.
rex89sir2
Aug 28, 2009 02:36 PM
janz3n
Apr 14, 2007 06:06 PM
5thGenKing
Oct 28, 2004 06:57 AM
Donkey85
Jul 27, 2004 03:24 PM
FlexW99
Feb 27, 2004 11:51 AM
