mini me questions
Old Mar 20, 2005 | 10:47 PM
menappi's Avatar
Default mini me questions
ok so i have some questions reguarding the mini me. and yes i searched...
-is there a way i can use my obd0 (88crx si) dizzy with a y8 head. i read it bolts up fine (no cutting) but am wondering if it will cause problems with timing, etc.
-i can pickup a obd1 dizzy for 10 dollars, but it has a bad ignition control module. is there a way i can swap the one from my crx dizzy into the obd1 dizzy, saving myself 100 dollars?
-if i use the y8 injectors, does that change the wiring? do i need to remove the injector resistor box?
-i have a choice of using either a Z6 or A6 intake manifold. the A6 i have and the Z6 i can get for cheap. is there any benefits to one or the other? more power? etc.
-if i plan on boosting, should i use a z6 or y8 head gasket?
Old Mar 21, 2005 | 06:58 PM
menappi's Avatar
bump plz i need some help
Old Mar 21, 2005 | 07:35 PM
mr. carpenter's Avatar
Default Re: (menappi)
search better. the dist. needs to match the ecu you are using so unless you get a zdyne or hondata or something similar.
the ignition control modules are interchangeable in that they can be replaced but not swapped. i think? someone correct me if i'm wrong.
i've been told the z6 manifold is better though i currently run the a6. supposedly the y8 manifold is the best but from my reading i've found it to be debatable.
i ound most of these answers searching for a few minutes. i'm not sure about the injectors or boosting. good luck
xwhitchx
Mar 23, 2009 01:59 PM
99_itr
13
Dec 24, 2007 10:24 PM
viskii420
17
Oct 29, 2006 09:01 AM
justinau
Aug 31, 2004 07:26 AM
project dc2
Dec 19, 2002 10:42 PM
