Need Suspension advice/help.
Old Jan 24, 2002 | 05:46 PM
mycronman's Avatar
Default Need Suspension advice/help.
Ok i just purchased some H&R race springs/koni yellows for my 96 civic Ex. Now while im installing these i figure a lower tie bar wont be a bad idea either. what do you guys recommend? Should i get a lower tie bar and what do you guys suggest (used if possible). What about an upper strut bar? Ok thnx for the help and if you sellin anything e-mail me :
hallbrown@enter.net
Old Jan 24, 2002 | 06:31 PM
Stephen's Avatar
Default Re: Need Suspension advice/help. (mycronman)
screw the tie bar, get a sway bar. I have both, and the SWAY bar is about a dozen times more effective.
I believe that the 96 Civic has the same rear subframe as a G3 Integra. That would mean a swaybar for an Integra would work fine. The ITR bar is the most effective for the $.
Old Jan 24, 2002 | 06:40 PM
mycronman's Avatar
Default Re: Need Suspension advice/help. (Stephen)
cool thanks for the reply. Do you suggest getting the rear strut bar along with the sway bar? Thnx
Hondacivic90ed
18
Sep 19, 2007 09:09 PM
YoungMoneySi
Suspension & Brakes
Apr 18, 2006 11:30 AM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
T_Rex
36
Jan 23, 2003 05:45 PM
IgniteTeg
Sep 11, 2001 02:02 PM
