building a sedan, integra suspension.
Old Mar 20, 2005 | 10:08 PM
JDMorgan's Avatar
Default building a sedan, integra suspension.
hey guys, i decided to build a 90 sedan. i have no idea about what will fit from my 92 integra parts car. i am looking to swap as much of the suspension as possible. could i litterally unbolt the upper and lower control arms from the sub-frame in the front, and unbolt the toe bar from the trailing arm and upper+lower from the subframe. then bolt them all on the same on the sedan? whats required to use sway bar? do i need to use the civic struts/springs, forks and rear lca's? post as many links as possible if you could. im planning to use a zc sitting around at my shop, and thats about it.
Old Mar 20, 2005 | 10:26 PM
JDMorgan's Avatar
also should i do the prop. valve and master cyl/booster?
Old Mar 21, 2005 | 04:11 AM
ex voto's Avatar
Default Re: (KraZEtEggIE)
I would only do the proportioning valve if you plan on doing a rear disc swap. The EX's came with a few Integra suspension parts... like the front spindles, larger master cylinder and larger brakes.
89ED
10
May 4, 2013 05:12 PM
JayDM-hatch
Nov 21, 2007 06:19 PM
dc5mikeydc5
Apr 14, 2006 11:03 PM
JDMlyfestyle
Suspension & Brakes
Jul 7, 2005 11:36 AM
hmulyo
Oct 4, 2004 07:45 AM
