My prelude stambles when lunching ????????? help
Old Mar 20, 2005 | 09:14 PM
gridelock's Avatar
Default My prelude stambles when lunching ????????? help
I have had this problem after I did my swap .. usauly! let say you are in first gear revit up to 3-4000 rpm you let go of the clutch , it either lunchs or smoke tires ,, right !! but mine stumbles really bad, about 4 sec later it picks up speed at high RPM.. I was not sure but I think it might be the Distr , replaced the cap . rotor button .. Has any one had this problem ..
I'm not what the problem is Please if any one knows what problem might be let me know
Any advise is need ,,,, thanks
Old Mar 20, 2005 | 09:51 PM
WifesVTEC's Avatar
timing.
I had the exact same problem with my 84 Supra after My brother in law put on a new timing belt. Its always a good idea to check the timing and timing belt when you put in a new motor.
Old Mar 20, 2005 | 09:59 PM
edulerp97's Avatar
Default Re: (WifesVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WifesVTEC &raquo;</TD></TR><TR><TD CLASS="quote">timing.
I had the exact same problem with my 84 Supra after My brother in law put on a new timing belt. Its always a good idea to check the timing and timing belt when you put in a new motor.</TD></TR></TABLE>
That sounds about right..
Old Mar 21, 2005 | 01:22 AM
SNsLude's Avatar
Default Re: (edulerp97)
would you say you can describe your problem as a bogging/choking effect?... if so it may not just be the timing belt... from how you're describing it, it sounds like the usual bogging problems some people come accross from time to time...
ive read alot of people solve this problem from various areas, from a simple ecu reset to having to buy new knock/o2 sensors...
more cases then not though, timing did help improve the problem if not solve it... timing belt could be good but your distributor could be misplaced or retarded... usually after people have swapped engines or have had shops swap it out, in some cases when moving the distributor around, people forgot to jump the service connector or else the ecm will automatically adjust the timing...
hehe i guess just try getting a timing light first and see where you are at... should be at 15 deg i believe? just something simple to try out first
DraginTeg93
Jan 29, 2010 12:02 AM
Lokisdope
Oct 7, 2007 07:48 PM
superturboprelude
Jun 12, 2004 07:59 PM
kuja
Dec 30, 2003 10:12 AM
