head bolts
Old Mar 20, 2005 | 08:09 PM
jjaskula1's Avatar
Default head bolts
I am doing a head swap on my 93 Civic DX. i am doing a mini me. while i was doing all this i figured i would swap the crank out because of a chunk missing from the grove in the crank were the pulley goes.. is it possible to just just change the crank with out changing rods and pistons?? thanks.
Old Mar 20, 2005 | 08:14 PM
Lord Helmet's Avatar
Default Re: head bolts (jjaskula1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjaskula1 &raquo;</TD></TR><TR><TD CLASS="quote">
I am doing a head swap on my 93 Civic DX. i am doing a mini me. while i was doing all this i figured i would swap the crank out because of a chunk missing from the grove in the crank were the pulley goes.. is it possible to just just change the crank with out changing rods and pistons?? thanks.</TD></TR></TABLE>
yes you can just replace the crank. just get new bearings for both.
Old Mar 20, 2005 | 08:23 PM
jjaskula1's Avatar
Default Re: head bolts (sleeperciv)
I am doing a mini me swap... A d15B7 Block with a D16Z6 Head.. what head bolts do i use for that? Just standard D15? thanks
Old Mar 20, 2005 | 08:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjaskula1 &raquo;</TD></TR><TR><TD CLASS="quote">I am doing a mini me swap... A d15B7 Block with a D16Z6 Head.. what head bolts do i use for that? Just standard D15? thanks
this should help you out a lot: https://honda-tech.com/zerothread?id=554053
jrscb16eg6
Aug 12, 2008 03:02 PM
ceyazzie
Jul 1, 2007 04:21 PM
jjaskula1
Mar 19, 2005 01:07 PM
turbo_ef9
Mar 5, 2002 09:23 AM
