Axles - Base vs. SH
Old Mar 20, 2005 | 07:28 PM
Shakes's Avatar
space cadet
Default Axles - Base vs. SH
what is the difference between them? i installed a drivers side base axle into my SH (with H23 intermediate shaft / base engine) and now if i cut corners hard i get a jittering. i even had one clunk noise can it be the axle?
Old Mar 20, 2005 | 09:48 PM
Shakes's Avatar
space cadet
Default Re: Axles - Base vs. SH (Shakes)
night crew... anyone?
one person has said leingth, but not sure how much of a difference there is or if there are any other differences
Old Mar 20, 2005 | 09:56 PM
edulerp97's Avatar
Isn't the h23 intermediate shaft longer than the h22 intermediate shaft. Say that again. Night shift !!!
Old Mar 20, 2005 | 10:00 PM
Shakes's Avatar
space cadet
Default Re: Axles - Base vs. SH (edulerp97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the h23 intermediate shaft longer than the h22 intermediate shaft. Say that again. Night shift !!!</TD></TR></TABLE>
it shouldnt be.
this problem would be (if leingth is the issue (i swear she said it was fine!!!!) that the axle is too short. from the feel of it its only milimeters if it is off.
Old Mar 20, 2005 | 10:02 PM
edulerp97's Avatar
Okay let see the h23 intermediate shaft comes from the 92-95 prelude right....
Old Mar 20, 2005 | 10:22 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">Okay let see the h23 intermediate shaft comes from the 92-95 prelude right....</TD></TR></TABLE>
considering it wasnt offered in any other years yes.
Old Mar 20, 2005 | 10:41 PM
edulerp97's Avatar
Isn't the width of the 4th gen wider than the 5th gen. If I am not mistaken it's about .5 inches wider. Therefore it makes the h23 shaft longer than the h22 shaft. I could be wrong.....If I am, sorry for wasting your time and giving you the wrong info. But It doesn't hurt to check......
Old Mar 20, 2005 | 10:45 PM
Shakes's Avatar
space cadet
we are NOT talking about the shaft being too wide, but rather the axle being too short.the h23 intermediate shaft is fine. everything was perfect with the SH axles, but now under turning with a BASE axle i get a jittering feeling at times.
Old Mar 20, 2005 | 10:52 PM
edulerp97's Avatar
Sh-t.... I misunderstood you.... My bad.......
Old Mar 20, 2005 | 10:57 PM
edulerp97's Avatar
You can fix that real quick get another sh axle......
Old Mar 20, 2005 | 11:00 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">You can fix that real quick get another sh axle......</TD></TR></TABLE>
of course, but i would rather find out what the difference is between the two so that i know. knowledge is power.
Old Mar 20, 2005 | 11:45 PM
edulerp97's Avatar
You are right about that.......
Old Mar 21, 2005 | 05:01 AM
Shakes's Avatar
space cadet
ok, anyone for the day crew
Old Mar 21, 2005 | 05:29 AM
Daemione's Avatar
You probably know this, but they are different part numbers for the base & SH driveshafts.
That said, the few people I've found talking about it implied that there was no difference, and they were interchangeable . . . . **shrug**
Old Mar 21, 2005 | 05:34 AM
JadedGamerX's Avatar
Default Re: Axles - Base vs. SH (Daemione)
I guess I have no proof but I am 100% certain that they are not the same. This question has came up before shakes, and they found them to be like 3mm short or something and one guys even popped out and caused one wheel not to get power at all.
Get the SH axle.
Old Mar 21, 2005 | 07:59 AM
Shakes's Avatar
space cadet
Default Re: Axles - Base vs. SH (JadedGamerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">I guess I have no proof but I am 100% certain that they are not the same. This question has came up before shakes, and they found them to be like 3mm short or something and one guys even popped out and caused one wheel not to get power at all.
Get the SH axle.</TD></TR></TABLE>
yeah, when we called ARI to get the shaft they said they were different. i went with the base due to having a base engine / tranny. i guess its the difference in the knuckle rather then the half shaft vs atts unit.
Old Mar 21, 2005 | 03:52 PM
Shakes's Avatar
space cadet
i got an SH axle in today and it is even worse.
ball joint possible?
it feels like ABS is on when i turn.
Old Mar 21, 2005 | 08:38 PM
Wow man... wow. Check out your lower control fork or whatever, I hit a curb in my SH and it made it rumble and bumble like crazy... brain fart on the actual name of the part. Lower Control Arm? I don't know I've been up 27 hours straight now.
Old Mar 21, 2005 | 08:45 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">Wow man... wow. Check out your lower control fork or whatever, I hit a curb in my SH and it made it rumble and bumble like crazy... brain fart on the actual name of the part. Lower Control Arm? I don't know I've been up 27 hours straight now.</TD></TR></TABLE>
Yeah, lower control arm. Get some sleep man.
Lower control fork
Old Mar 21, 2005 | 08:46 PM
Shakes's Avatar
space cadet
that thing is ok. everything is solid, i just dont get it.
anyhow, my firend owns the shop that got me the axel so he talked to the people that made it / procured it from another shource, and they are going to rebuild my original axel and trade back for the other one. if its fixed then, then ARI axels just suck. if not then im going to be rather pissed off.
Old Mar 24, 2005 | 06:58 AM
well in any case I hope u get this **** figured out shakes. Oh, and BTW... dude I need to quit smoking again... I dipped back in after a nasty breakup. I hate women. All of them.
Old Mar 24, 2005 | 07:31 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">well in any case I hope u get this **** figured out shakes. Oh, and BTW... dude I need to quit smoking again... I dipped back in after a nasty breakup. I hate women. All of them. </TD></TR></TABLE>
im still going strong thankfully. had a lot of cravings though. i just keep reminding myself of how much i spent on smoking.
back on topic though, i think that the knuckle is different. i described it as feeling like ABS was kicking in when i turned. the other day i hit the brakes in the rain (nobody around) and the passenger side went into abs, the drivers side did not.
i should have my other axle back soon though.
Rob97'SH
Jan 30, 2013 07:37 PM
pullin crx hf
Aug 10, 2011 03:19 PM
shiux
Oct 18, 2009 06:02 PM
THC07
Sep 21, 2006 06:49 AM
T"u"Rtle
Nov 6, 2005 11:10 AM
