'91 Civic Hatch -> B18C1
does anybody have any experience with such a swap? i couldnt find anything in the search. please help me with any articles i may have missed for i am a noob in the vBulletin department.
and please give me any input you might have, yourself. i studied EG -> B18C1 swap well, since that was my original plan, but i got a great deal on a squeaky clean 91 hatch.
- THANK YOU VERY MUCH -
easy stuff.. here is a list of what you'll need..
b-series mount kit..
b16a1 side mount (the one that bolts to the block)
b-series shift linkage (hasport/place/hcp)
88-99 integra axles.. depending on what int shaft you use
if your car isn't an hf or si then you'll need to do a mpfi swap.. you 2 choices to run ur motor.. either stick with obd0 (what an 88-91 civic/crx is) or run obd1.. to run either or, you'll need the correct distributor and distributor plugs, and for obd1 a obd0-obd1 jumper harness.. wire vtec, oil pressure, etc.. if you do plan to keep it obd0 it'll be best to get a skunk/aebs/etc. intake manifold since a gsr does have butterflies.. its fairly step by step procedure.. dont take short cuts
if you have any more ?'s just pm me..
Hit up droppedcrxsi's site.
http://www.norcalcrx.org/droppedcrxsi/
Everything you will need to know.
DIGITAL6903
Sep 4, 2008 04:31 AM
idontcare
Nov 28, 2003 07:47 AM
