EK Civic - Brake conversion question.....
Is it possible to mount front disc brakes onto the back of an EK civic (it would be a rear disc conversion and the front brakes on the back would be a bigger size than GSR or Si rear discs) -- So, from a technical view, is it possible?
Thanks guys!
Thanks guys!
Does it matter if the trailing arms have the rear drum setup on it? Or do I need trailing arms for a rear disc setup?
I'd get rear disk brakes from an Si, Integra, or 92-95 EX/Si. Everything bolts up, but you need to use your LCA. A problem I see is that for the front hubs, you have the axle spindle going through it.
Chefskinny
Apr 15, 2015 05:48 PM
PardonmyEK9
Jul 9, 2010 07:48 AM
