reground crank...
Old Mar 20, 2005 | 06:51 PM
hondaeg8's Avatar
Default reground crank...
how much can the main journals be regrounded on a gsr crank?
Old Mar 20, 2005 | 07:33 PM
AdamBOMB_STi's Avatar
Default Re: reground crank... (hondaeg8)
not sure how much it can be ground. but when i rebuilt my motor my machinist had my crank sent out to get reground and bearing to fit with perfect clearance.
Old Mar 20, 2005 | 08:22 PM
da9project's Avatar
check by seeing what the largest size bearing honda makes for it is, i would assume .020-.030
Old Mar 20, 2005 | 09:18 PM
hondaeg8's Avatar
Default Re: (da9project)
i think the main journals need to be grounded .010 under and the machinist said i could still use std bearings. i'm guessing std bearings from honda, not sure, but he will be the one ordering the bearings for me once all the clearances are checked.
Old Mar 20, 2005 | 09:23 PM
W C L's Avatar
Default Re: (hondaeg8)
.10in and .50in i believe..... u'll be ok jsut make sure it put back together right
Old Mar 20, 2005 | 09:28 PM
hondaeg8's Avatar
Default Re: (W C L)
sup W C L ?
i was going to pm you and ask you about this, but i posted it.
i think i'll pm you anyway
Old Mar 22, 2005 | 12:50 AM
hondaeg8's Avatar
t_can
Engine Machining & Assembly
27
Jun 27, 2017 10:23 AM
GReddy SI
Jun 6, 2012 09:31 PM
ShortbusEK
Mar 7, 2008 01:29 PM
acrocat
Jun 15, 2007 06:34 AM
hondaeg8
May 1, 2005 12:15 AM
