Suspension & Brakes Theory, alignment, spring rates....
'00 rear sway bar onto a '00 hatch - what do I need?
Old Mar 20, 2005 | 06:23 PM
fireant's Avatar
Default '00 rear sway bar onto a '00 hatch - what do I need?
I see there appears to be some (non-threaded) holes on the rear LCA of my wife's '00 hatch for endlinks and d-brackets. I'm wondering if the '00 rear sway bar just swaps straight over to the DX chassis or not? Anyone know?
Old Mar 21, 2005 | 10:21 AM
Smashback's Avatar
Default Re: '00 rear sway bar onto a '00 hatch - what do I need? (fireant)
Yes it does. I believe only the Si came with one. 13mm if I remember.
Old Mar 21, 2005 | 10:41 AM
fireant's Avatar
Default Re: '00 rear sway bar onto a '00 hatch - what do I need? (Smashback)
Thanks, I'm guessing a second-hand Si bar would be easy to come by, and a good-enough upgrade for a daily driver. I was just unsure because the holes are there, but not threaded.
Old Mar 21, 2005 | 12:31 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I'm guessing a second-hand Si bar would be easy to come by, and a good-enough upgrade for a daily driver. I was just unsure because the holes are there, but not threaded.</TD></TR></TABLE>
Yeah...the holes don't need to be threaded because the endlink bolt uses a nut to secure it to the LCA.
Old Mar 21, 2005 | 01:23 PM
fireant's Avatar
Default Re: '00 rear sway bar onto a '00 hatch - what do I need? (gabebauman)
excellent!
Old Mar 22, 2005 | 10:27 AM
kommon_sense's Avatar
bar is a direct bolt-on. Only thing to keep in mind is that the holes in the rear subframe to mount the sway bar brackets are not threaded, so you have to slide a nut on the backside of it. The dealer diagrams don't show this little detail...
SiShane
Oct 3, 2004 01:08 AM
crazy_ham
Sep 21, 2003 01:25 PM
daddyrich1227
Jun 17, 2003 06:05 PM
TeamSTEALTH GSR
Jun 1, 2003 08:38 PM
d0nkeyxPunch
Feb 23, 2003 03:01 AM
