12.721 @ 108.30 pass at NOPI Phoenix (more hope for the NA guys)
Old Mar 20, 2005 | 05:26 PM
2point6's Avatar
Default 12.721 @ 108.30 pass at NOPI Phoenix (more hope for the NA guys)
The first day started out cold, a little breezy, and sprinkled on and off slightly throughout the day. My first pass wasn't very good as I miss shifted and ran a 13.81 @ 101.77 (1.770 60ft). I got laughed at bad... Robert (my shop head mechanic) was talking some trash about the nasty sounds of "non driving fool" (he said worse) miss-shifting on the track and then he found out it was me, so he rubbed it in a bit. I learned how to drive right after that and followed up with a 12.94 @ 106.2 (1.795 60ft). One really cool thing was my 60ft times. I finally broke into the 1.7's. My third pass was a 13.00 @ 106.49 (1.80 60ft). A little off mark, but consistant enough to back up my other passes. Pass #4 was the quickest of the day where I ran 12.81 @ 107.1 (1.772 60ft). I was excited since I broke my previous record, and this was also the first of my 3 "qualifying" runs for the COMP 4 class. Qualifying round 2... I miss-shifted into third again and this time hurt the tranny. Coming off the track I was unable to downshift without things feeling really notchy. I went to slow down into 1st and nothing but grindage. Rain sat in as I tried to figure out what I had done to the tranny. The event cancelled for the night as I drained the tranny to start my inspection and all I saw was brass sparkles in the fluid. NOT A GOOD SIGN. The cops came and started asking people to leave, so I was unable to go further with my teardown. The next morning I decided to just take my chances... I filled the tranny up and went for a test drive. Shifted fine, but downshifting sucked. GAME ON! The third qualifier was for the quick 8 and I was sitting in 8th clinging to my spot. All I had to do was beat my first qualifying time. I did not, I ran a 12.84 @ 108.49 (1.769 60ft). I was excited that my MPH went way up and even more excited to find out I had qualified to the Quick 8. So the Elimination rounds were next. I was done for... I was the only oddball among an entire field of civics. Gutted and cut up civics, no less. This drew some positive attention from the anouncer who pointed out that I had the only full factory bodied/glassed 4dr ACCORD in the field. This made quite a few people take notice. My last pass, although I was beat by a much lighter car was my best of the event. I pulled off a 12.721 @ 108.30 (1.753 60ft)
Old Mar 20, 2005 | 05:33 PM
high_revs's Avatar
congradulations man
Old Mar 20, 2005 | 05:38 PM
SUB-0 H23's Avatar
Default Re: 12.721 @ 108.30 pass at NOPI Phoenix (2point6)
nice it is cool how you stick w/ the accord
Old Mar 20, 2005 | 05:42 PM
polishprinze's Avatar
Default Re: 12.721 @ 108.30 pass at NOPI Phoenix (SUB-0 H23)
what was your set up?
Old Mar 20, 2005 | 05:45 PM
edulerp97's Avatar
Default Re: (h23 killa)
Congrats..man...Very nice numbers...Way to go for the NA brothers. I know it's not me and others probably wants to know as well, but what are your specs........ congrats.........
Old Mar 20, 2005 | 05:52 PM
gundamgsr's Avatar
that's geat bro.
i owned a civic hb and my pelude, but had to give one up when i moved. i chose the civic to give up, and since then kind of regretted it. mainly because of the weight difference.
but now, since seeing this, i feel a little more comfortable with my choice. i guess i can still be fast.
what mods have you done to your motor? you can pm me if need be.
Old Mar 20, 2005 | 05:58 PM
edulerp97's Avatar
Default Re: (gundamgsr)
I think we all feel that way because I gave up my GSR Integra for my 97lude. We are curious of what mods he has.......
Old Mar 20, 2005 | 06:24 PM
2point6's Avatar
Default Re: (edulerp97)
Engine Block: '93 H22a "bored and stroked" to 2.44ltrs of displacement built by Myself at Collective Racing. Custom crank (Balanced and nitrited), Darton sleeves, Crower Pro-billet rods, Custom 12/1 compression JE pistons, Prodrive oil pump, Accord Type R crank pulley, manual timing belt tensioner conversion, power industries timing belt.
Cylinder head: Ported and polished by Collective Racing, Web Cams custom camshafts, Web Cams springs and Titainium retainers, Euro Type R manifold conversion, Erick's Racing 70-68mm Throttle body, RC engineering 440cc Fuel injectors, B&M fuel pressure riser and Guage, STR cam seal, STR cam gears, SMSP header, ARP head/main studs, Cometic head gasket.
Misc: JDM "blue" valve cover, Dyna Batt 11lb. battery, AEM 3" cold air intake, Hondata
Old Mar 20, 2005 | 06:29 PM
PirateMcFred's Avatar
Does anyone search for user's posts anymore? You think that a 247whp H22 is not going to have some sort of write-up? Search, Prelude Forum archives, author: 2point6. He even has a link to his site in his sig.
Anyway, 2point6 that is awesome!! Are you going to tear down the transmission to see if everything is alright?
Pirate
Old Mar 20, 2005 | 06:36 PM
edulerp97's Avatar
Default Re: (PirateMcFred)
Bad ***...That is nice **** you have in there.....What EMS did you use? **** now looking at your injectors I think Mine might be to small......**** again...
Old Mar 20, 2005 | 06:38 PM
edulerp97's Avatar
oops my bad I see it....WHat computer? p-28 or? s200?
Old Mar 20, 2005 | 06:42 PM
2point6's Avatar
p28 with s200
Pirate, yes I got to tear it down to see what happened. I have to do it tomorrow since I have a daughter that needs to get to school and back. It is tough racing the family car. LOL.
Old Mar 20, 2005 | 06:51 PM
Default Re: (2point6)
HAHA, I hope that it is easier to drop a transmission in an Accord than it is in a Prelude. Takes me about 5 hours to do a transaxle swap...
Pirate
Old Mar 20, 2005 | 06:58 PM
MeUglyDuckie's Avatar
very nice numbers congrats
Old Mar 20, 2005 | 07:14 PM
BolivianFuego's Avatar
Default Re: (MeUglyDuckie)
Good **** bro. Keep trying to cut down the 60ft and you will be ***** to the wall faster.
Old Mar 20, 2005 | 07:22 PM
Shakes's Avatar
space cadet
Default Re: (BolivianFuego)
**** downshifting
keep it up scott!!! we want low 12's by the end of this season
Old Mar 20, 2005 | 07:32 PM
2point6's Avatar
Default Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">**** downshifting </TD></TR></TABLE>
That is exactly what I said...lol and my daughter charges me for every cuss word I use in front of her. It was a very expensive weekend. she is set for college now.
Old Mar 20, 2005 | 07:56 PM
edulerp97's Avatar
We want low 12's!!!!!!
Old Mar 20, 2005 | 07:57 PM
Hawkze_2.3's Avatar
Great job! It's guys like you that give us hope when people say it can't be done.
Old Mar 20, 2005 | 10:23 PM
dkturbo's Avatar
:D
Old Mar 20, 2005 | 11:24 PM
Akhany's Avatar
Default Re: (dkturbo)
ownage to the max.
Old Mar 20, 2005 | 11:41 PM
es_squared's Avatar
Default Re: (Akhany)
*clapping* very very impressive man.
Old Mar 20, 2005 | 11:45 PM
DLB1994's Avatar
dam good she getting faster , im ready to get back to the track i need some new times lol
Old Mar 21, 2005 | 12:11 AM
@ries's Avatar
nice! keep up the good work.
Old Mar 21, 2005 | 07:20 AM
se93's Avatar
Default Re: (@ries)
Scott:
Same here, keep up the good work!
