How do i go about changing my tranny fluid?
Old Mar 20, 2005 | 04:29 PM
dude8383's Avatar
Default How do i go about changing my tranny fluid?
The car shifts kinda roughly and i wanna change the oil in there...but i have absolutely no idea where the drain/filler holes are!!
Old Mar 20, 2005 | 04:32 PM
EK k kay's Avatar
Default Re: How do i go about changing my tranny fluid? (dude8383)
http://www.c-speedracing.com/h...d.php
Follow that, but instead of filling it from the side bolt, take off the vehicle speed sensor at the back of the tranny and fill it from there using a long neck funnel.
Old Mar 20, 2005 | 04:54 PM
Kyles ej1's Avatar
Default Re: How do i go about changing my tranny fluid? (chowmien)
y, i filled it from that bolt and it was fine
Old Mar 20, 2005 | 05:05 PM
screech's Avatar
Default Re: How do i go about changing my tranny fluid? (93ejay1)
cuz everytime you change your tranny fluid its time to clean your filter so knock out two birds with one stone (cuz you have to take the intake off to get to the speed sensor)....or atleast its that way down here in texas raining all the fucken time....and goin to the beach
Old Mar 20, 2005 | 05:09 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">y, i filled it from that bolt and it was fine</TD></TR></TABLE>
I find it much easier to fill from the speed sensor location. To each his own I guess.
Old Mar 20, 2005 | 05:11 PM
skunk2finatic's Avatar
wurd
Old Mar 20, 2005 | 05:23 PM
Jedi_Sol's Avatar
Default Re: How do i go about changing my tranny fluid? (skunk2finatic)
Old Mar 20, 2005 | 05:29 PM
Kyles ej1's Avatar
Default Re: How do i go about changing my tranny fluid? (Jedi_Sol)
well i have acces to a lift, so its easy for me
Old Mar 20, 2005 | 05:34 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread?id=1184914
i just did this write up last night with pennzoil syncromesh
Old Mar 20, 2005 | 05:56 PM
butters's Avatar
Default Re: How do i go about changing my tranny fluid? (yebabee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1184914
i just did this write up last night with pennzoil syncromesh</TD></TR></TABLE>
good job on that write up nice and easy to follow.
Old Mar 20, 2005 | 06:22 PM
dude8383's Avatar
AWESOME!! thanks for the links and helpful advice..now i gots to order me some GM Syncromesh
Old Mar 20, 2005 | 10:25 PM
Morning Call's Avatar
hmm
u guys fill the tranny alot different then me
i drained with the normal drainhole.. and filled it right up top of the tranny... theres a lil tit sticking out of the tranny with a rubber plug on the end... i put a peice of rubber on there and then a funnel on that rubber and poured it in
but now that i see this... did i even fill the right spot? lol when u drained the fluid again i did notice it didnt quite match up to the amount i put in... but the color was relatively not as dark as when i first drained it
Old Mar 21, 2005 | 05:25 AM
dude8383's Avatar
im thinking it may have been the plug for the flywheel line up...i forgot exactly whats its called..but my golf's tranny had a plug like that also, and pouring fluid in there is really gonna **** something up in there!!
Old Mar 21, 2005 | 05:34 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: (dude8383)
did anyone else notice he didnt actually say whether the transmission fluid was for a automatic or manual?
Old Mar 21, 2005 | 07:21 AM
dude8383's Avatar
oh yeh...lol
Old Mar 21, 2005 | 07:41 AM
alotawatts's Avatar
Also .....for older cars when changing trans fluids and especially differential fluids in rear wheel drives cars it's always a good idea to loosen the filler bolt first before you drain. Otherwise if you drain first and then find your filler bolt is seized up for some reason you're f*cked.
Old Mar 21, 2005 | 07:48 AM
EJ1 wilcox's Avatar
Default Re: How do i go about changing my tranny fluid? (alotawatts)
I always just fill it from the VSS hole... I don't have to take of my intake or anything either, I have a long funnel...
Takes less than 10 min to change tranny fluid... super duper easy!
Oh, careful not to over tighten the bolt that holds the VSS in place, the first time I changed my fluid I over tightened it and broke the mounting bracket...
Old Mar 21, 2005 | 09:23 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: How do i go about changing my tranny fluid? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">did anyone else notice he didnt actually say whether the transmission fluid was for a automatic or manual?</TD></TR></TABLE>
Honda makes AUTOMATICS!!!!
Old Mar 22, 2005 | 12:56 AM
DunDaDa_EK9's Avatar
da fill plug so u kno how much u need 2 fill up. don't need to many fluid in there, to the bolt n that's it.
Old Mar 22, 2005 | 01:18 AM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: (Morning Call)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call &raquo;</TD></TR><TR><TD CLASS="quote">hmm
but now that i see this... did i even fill the right spot? lol when u drained the fluid again i did notice it didnt quite match up to the amount i put in... but the color was relatively not as dark as when i first drained it</TD></TR></TABLE>
I think you're reffering to the tranny breather. I've heard of other people filling through there. You should be fine, they've had no problems.
Old Mar 22, 2005 | 01:35 AM
civiccoupe94's Avatar
im about to change the Manual trans fluid for my 94 dx coupe, and the guy at NAPA sold me 2 quarts of 10w 30 motor oil, as he was reading the helms manual or chiltons, i forgot, but he was reading some manual and said its ok to use that as trans fluid for the next 30k or so. will motor oil work great? and will it **** up my trans?
Old Mar 22, 2005 | 01:56 AM
Ragecloak's Avatar
My haynes manual said 10w30 as well. I think it should be fine, but after hearing about that penzoil sync fluid or whatever the hell it's called, i'm going with that. I dont like to skimp when it comes to fluids. Dunno why, i just don t
Old Mar 22, 2005 | 06:59 AM
EJ1 wilcox's Avatar
Default Re: (Ragecloak)
Don't use the 10w30 that was suggested to you!
Go to Honda and get some real Honda Manual Transmission Fluid, it's different than 10w30 oil and works much better...
There has been a lot of discussions about this but I will give my experience...
I put regular 10w30 oil in my transmission a few years ago because that's what my manual said to put in there... after a few months my shifts became VERY notchy and it would have a hard time going into gear when it was cold outside. I did some reading and learned that MTF has different properties than regular oil. So, I bought some Honda MTF and got rid of the 10w30 oil that was in there... I noticed an instant night and day difference! It shifted sooo much smoother and was not notchy anymore, it would slide right into gear even when it was cold!
Since that experience I have been a firm believer in Honda MTF and recomend it over using regular oil like the Haynes manual suggests. You will have smoother shifts!
Plus, Honda MTF isn't any more expensive than conventional oil, in fact, I think it's cheaper! Oh, and I don't know about other special transmission fluids, but I know that Honda MTF works well so that's what I stick with...
Old Mar 22, 2005 | 07:57 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (EJ1 wilcox)
Don't forget to replace the drain-plug & fill washers every time you remove them. Thier only about $.25 each, so buy a bunch the next time you go to honda. The drain plug washer is the same as the oil pan drain plug washer. The fill plug is quite a bit larger...
Old Mar 22, 2005 | 10:17 AM
panix's Avatar
thanks for the help
