Best header for a b18c1?
Old Mar 20, 2005 | 01:58 PM
EtchaSketch's Avatar
Default Best header for a b18c1?
I have DC sports 4-2-1 setup runnin right now, and have had lots of thoughts of changing off of it. Just curious on what has been shown to give better numbers or if i should just get a custom job done?
Old Mar 20, 2005 | 03:46 PM
GeeReg's Avatar
Default Re: Best header for a b18c1? (EtchaSketch)
How much money do you have?
Old Mar 20, 2005 | 04:26 PM
soLSvtec12kcraze's Avatar
SMSP....save up for one....
Old Mar 20, 2005 | 05:05 PM
Default Re: Best header for a b18c1? (GeeReg)
Well i need to know what im expectin to spend. Lets just say Money is not a huge issue but if something is REALLLY expensive and the gains are just not worth it then i could care less.
So if the header is worth the money then ill buy it but if im getting like more 2hp and spendin 500 dollars more for it then no thanks
Old Mar 20, 2005 | 08:02 PM
if money isnt an issue than go with the best on the market, dynograpically speaking....SMSP...
if u care enough about a header check out ANY header test,,,,youll seee.....
Old Mar 20, 2005 | 09:27 PM
VTECJUN's Avatar
Default Re: (soLSvtec12kcraze)
http://www.DTR-FAB.com
Old Mar 21, 2005 | 06:55 AM
black_EM1's Avatar
Community Builder
Community Influencer
Cheap- ITR works great
Expensive-SMSP,Bisimoto, any number of race headers
Old Mar 21, 2005 | 09:09 AM
indeed, ITR is a good solid header....
Old Mar 22, 2005 | 04:49 AM
StorminMatt's Avatar
From what I have seen, all of these headers (DC, SMSP, etc.) seem to offer about the same HP per dollar. So it really boils down to spending ~$250 for ~4HP or ~$1000 for ~16HP.
Old Mar 22, 2005 | 01:47 PM
B18C2_sedan's Avatar
i run the dc 4-1 because I can not afford smsp
Old Mar 22, 2005 | 04:50 PM
AdamBOMB_STi's Avatar
dtr!! u might as well run a stock unit until u save enough for a header that actually gives good gains.
Old Mar 22, 2005 | 04:53 PM
Ketone's Avatar
Default Re: Best header for a b18c1? (kwik_B16)
don't forget toda, it has great gains, and awesome ground clearance
Old Mar 22, 2005 | 06:39 PM
DC2Hybrid1's Avatar
Default Re: Best header for a b18c1? (Ketone)
It all depends on your set-up. Is the motor Stock or built? If it stock I would stick with an ITR or DC header. Built- go with a nicer header SMSP or Hy-tech; it might be a lot more money but it'll be worth every penny.
itrawesome
Oct 30, 2009 08:02 PM
gsr_pimp88
Sep 8, 2006 04:35 AM
94_eg_hatch
Mar 9, 2006 01:04 AM
girliehonda
May 7, 2005 08:57 PM
rezaroy
Oct 5, 2001 02:03 PM
