TPS Sensor ? Please Help
Old Mar 20, 2005 | 01:56 PM
JDMTRSPORTS's Avatar
Default TPS Sensor ? Please Help
hopefully some one can help me, i bought a 1993 dx hatch has about 156,xxx on it. for some reason at any rate of speed the car wants to cut out, stall,jerks or something, the mph gauge flicks up and down and at a complete stop the car just dies out, its wierd some people have told me its the igniton coil and some others have told me its the tps sensor please help HONDA-TECH
Old Mar 20, 2005 | 03:03 PM
93_hatch's Avatar
Default Re: TPS Sensor ? Please Help (JDMTRSPORTS)
if it was the coil i think the car would just not start or even run, to see if it was ur tps some would have to check it, see if there is voltage dips in it which would cause the stalling and such
Old Mar 20, 2005 | 03:07 PM
Default Re: TPS Sensor ? Please Help (93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">if it was the coil i think the car would just not start or even run, to see if it was ur tps some would have to check it, see if there is voltage dips in it which would cause the stalling and such</TD></TR></TABLE>
how would i check for a voltage dip
Old Mar 20, 2005 | 03:48 PM
NitrousB.I.G.'s Avatar
Could it be the master relay (I think thats what its called). I have a similar problem but my car will start to studder, if I switch the ignition off then back on it everything is OK again, but the speedo doesnt turn off. Some one on Honda Tech said that this could be my problem and might be yours
Old Mar 21, 2005 | 08:24 AM
civic-4-ges's Avatar
Default Re: TPS Sensor ? Please Help (NitrousB.I.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousB.I.G. &raquo;</TD></TR><TR><TD CLASS="quote">Could it be the master relay (I think thats what its called). I have a similar problem but my car will start to studder, if I switch the ignition off then back on it everything is OK again, but the speedo doesnt turn off. Some one on Honda Tech said that this could be my problem and might be yours</TD></TR></TABLE>
I would be thinking along this line here...you are losing or shorting an electrical connection somewhere
Old Mar 21, 2005 | 08:32 AM
Default Re: TPS Sensor ? Please Help (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">
I would be thinking along this line here...you are losing or shorting an electrical connection somewhere</TD></TR></TABLE>
who would i have to take it to to find out exactly dealer ship or regular mechanic
Old Mar 23, 2005 | 06:21 PM
93_hatch's Avatar
unless u know electrical and such and have a DVOM or a DSO take it to someone that knows hondas, i personally like the dealerships but it cost alot
Old Mar 23, 2005 | 06:28 PM
2lua's Avatar
make sure all the grounds a good and secure.
Old Mar 23, 2005 | 06:30 PM
Aphelion's Avatar
didn't you get the memo? you forgot the cover sheet.
someone had to say it
Old Mar 23, 2005 | 06:44 PM
Default Re: TPS Sensor ? Please Help (Aphelion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion &raquo;</TD></TR><TR><TD CLASS="quote">didn't you get the memo? you forgot the cover sheet.
someone had to say it </TD></TR></TABLE> ok
Old Mar 24, 2005 | 02:30 AM
Not really....actually sounds very out of place
And to the poster...electrical issues are a PITA...I do not know that your dealer will be in a better position to fix it,over a small garage. Generally when something like this gets looked at, its hourly. If your mechanic is competant you may end up paying a little less than at a delaership based upon hourly rates.
Old Mar 24, 2005 | 03:57 AM
137's Avatar
137
no check engine light?
Old Mar 24, 2005 | 04:25 AM
hybridej7's Avatar
Default Re: TPS Sensor ? Please Help (137)
i was having kinda the same problem with my ls. was sputtering and stalling during driving and such. ended up being my dizzy was starting to crap out on me, so i swapped it with one i knew was good, been a year, no problems....
Old Mar 24, 2005 | 10:56 PM
Default Re: TPS Sensor ? Please Help (hybridej7)
no check engine light on at all just drove the car today and has same problem
Old Mar 28, 2005 | 02:45 PM
ttt
Old Mar 28, 2005 | 02:56 PM
2lua's Avatar
you asked question, we answered. did you do anything about it? as far as fixing it?
Old Mar 28, 2005 | 03:04 PM
Default Re: TPS Sensor ? Please Help (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">you asked question, we answered. did you do anything about it? as far as fixing it?</TD></TR></TABLE>
i finally got a day of this thur so its going into the shop. keep u posted thanks
jordan_civic
May 30, 2008 10:35 PM
valentine97
Jan 14, 2008 12:44 PM
actionanh
Nov 19, 2006 11:36 PM
SUPERSONICGSR99
Oct 1, 2004 04:03 AM
stizzit
Jan 24, 2002 08:30 AM
