4G rear camber adjustment needed to compensate stock setup
Old Mar 20, 2005 | 01:23 PM
cheezthis's Avatar
Default 4G rear camber adjustment needed to compensate stock setup
92 Si 4ws is the car...
Even w/the stock adjuster bolt, the rear right still has roughly 0.6 degrees of POSITIVE camber...not good.
Although it's impossible to see w/the eye, the rear right lca might be slightly bent. However, removing it could be a larger pain w/seized bolts on the shock and so on.
So...is there an inexpensive camber kit for the rears that allows you to increase negative camber; that way I could offset the current situations.
Thanks in advance, I need to have this done by this week.
huge230
Apr 8, 2006 05:22 PM
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
Valvola
Sep 10, 2005 08:45 AM
Kid1320
23
Feb 12, 2003 10:01 PM
