Coolant loss, low compression rough idle
Old Mar 20, 2005 | 01:20 PM
InTeGrA B18b1's Avatar
Default Coolant loss, low compression rough idle
can any1 tell me the problem without getting a leak down. Compression on the piston on the left side is 60. Could a blown headgasket cause a low compression in 1 cylinder or is it most likely rings. It smokes from exhaust. help me thanks.
Old Mar 20, 2005 | 01:50 PM
NJIN BUILDR's Avatar
Default Re: Coolant loss, low compression rough idle (InTeGrA B18b1)
Could be ring lands or head gasket.Either way the head's coming off.Should be obvious when you get that far.
Glenn
Old Mar 20, 2005 | 01:56 PM
Default Re: Coolant loss, low compression rough idle (NJIN BUILDR)
Yea thats what i am trying to figure out so i can get ready.
I was thinking if it is smoking and i lose coolant, it would be a head gasket.
Would a blown hg cause 1 cylinder low compression?I feel loss of power and now when i drive it is rough.
Old Mar 20, 2005 | 02:33 PM
ttt
Old Mar 20, 2005 | 02:38 PM
If it runs without loosing coolant and milkshaking the oil it is most likely ring lands.A head gasket can show low compression in one cylinder only,but you would have other symptoms.
Glenn
Old Mar 20, 2005 | 02:41 PM
Yea i lose some coolant and smoke and low compression in 1 cylinder. When i replace my head gasket I just dont want to be surprised with a bad ring and then i have to get the parts and have some more down time. thanks
Old Mar 20, 2005 | 03:18 PM
any other insights?
jason_SIR
Jul 7, 2015 05:04 AM
97itr86
Oct 30, 2004 08:51 AM
hellas
Mar 19, 2004 04:02 PM
BoostedSi
Apr 20, 2002 04:21 PM
Ri5e
Feb 10, 2002 09:54 AM
