Jdm type R EG 1/4
I have a question,what do you guys think a jdm type r in a eg will run with all the boltons and some good drag suspension with tunning. I'm curious so I want your guys oppinion.
Maybe if you can read alittle better and understand,you might know. I said thats what i have ,my question is what is it capable of running with all BOLTONS AND TUNED. DONT GET Mad at me because your prediction was way off.
Yes,everything is stock even the ecu.no tunning at all. I dont know about low 12's because i seen other hatches with type r swaps with built heads with stock bottom ends runing 12s.I heard the faster you go the harder it is to take off time so i wouldnt say its easy to figure out.
well then its a process of elimination. u ran high 12's <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokie »</TD></TR><TR><TD CLASS="quote">seen other hatches with type r swaps with built heads with stock bottom ends runing 12s.I heard the faster you go the harder it is to take off time so.</TD></TR></TABLE>so then mid 12's,see it really is easy to figure out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokie »</TD></TR><TR><TD CLASS="quote">I weight it 1970 fully gutted.I ran a 12.7 with slicks and a clutch with skinny bogarts in the back.</TD></TR></TABLE>
Post the slip.
Post the slip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Post the slip.</TD></TR></TABLE>
y u dont believe him?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">
y u dont believe him? </TD></TR></TABLE>
Did I say that? I want to see his numbers. Mainly his 1/8th mile time and trap speed as well as his 60ft and his final 1/4 mile trap speed.
And English apparently owns you.
12.7@108, with a 1.8 60 ft. keep that rear drag suspension on and hit the track again, with that mph 12.6 for sure, maybe 12.5s. one fast *** stock type r eg right there. thc style.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THCk20eg »</TD></TR><TR><TD CLASS="quote">12.7@108, with a 1.8 60 ft. keep that rear drag suspension on and hit the track again, with that mph 12.6 for sure, maybe 12.5s. one fast *** stock type r eg right there. thc style. </TD></TR></TABLE>
I'm a little confused... We talking about a K series type R or a B series type R? For a B series, those traps are WAY too high for a "stock" engine.
mylil bro has a site with videos,you can check it out. my cars the white one and the grey ones is thck20eg.Also,can youbelieve that yellow crx is stock and running 13.0???
out.http://www.freewebs.com/allmota831/carvideo.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokie »</TD></TR><TR><TD CLASS="quote">Mainly the trap speeds were around 106 and 108.ill post the slip when i have time.</TD></TR></TABLE>
So wait. No one has answered up here. Is this K series R or a B series R?
