egr code on h22 swap in an eg
Old Mar 20, 2005 | 12:51 PM
D-series ninja
Guest
Posts: n/a
Default egr code on h22 swap in an eg
how do you fix the egr code for an h22 swap in an eg... and the wandering idle? i assume you fix the code the idle would fix itself right?
but how do you fix the egr code? im just wonderin. any imput would be great
Old Mar 20, 2005 | 01:35 PM
Turbogixxer's Avatar
Default Re: egr code on h22 swap in an eg (ef-love)
Is it even wired up?
Old Mar 20, 2005 | 01:37 PM
fastwanabe's Avatar
You cant fix, erase or modify the EGR code unless you wire that bitch in. I suggest you run a P28 with an H22 program(Uber, Hondata)so that you dont get the CEL.
Wandering idle? adjust you FITV(right under the throttle body)then bleed you cooling system.
Old Mar 20, 2005 | 02:42 PM
2point2's Avatar
Default Re: egr code on h22 swap in an eg (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">You cant fix, erase or modify the EGR code unless you wire that bitch in. I suggest you run a P28 with an H22 program(Uber, Hondata)so that you dont get the CEL.
Wandering idle? adjust you FITV(right under the throttle body)then bleed you cooling system.</TD></TR></TABLE>
what he said. and block that EGR with a piece of aluminum.
Old Apr 4, 2005 | 07:00 PM
vtecvlow's Avatar
Default Re: egr code on h22 swap in an eg (2point2)
preludedriva
Dec 2, 2006 06:15 PM
spooolin
Nov 28, 2006 06:56 PM
hondasport2000
Apr 24, 2006 11:12 AM
1point7db2
Sep 2, 2004 04:23 PM
ranta18
Feb 19, 2003 08:55 AM
