do i P&P the head......
Old Mar 20, 2005 | 11:56 AM
hondaeg8's Avatar
Default do i P&P the head......
the head is currently off the block right now and i'm debating if i should get the head polished up. i'm thinking of maybe getting the intake side ported, just a little bit, nothing major, the exhaust side polished, the combustion chambers polished, along with some sort of valve job, nothing major on the valve job either. maybe just a 3 angle valve job at most.
the set up will be:
JDM GSR motor with usdm B16 pistons (should get around the 11.4:1 range)
JDM GSR head with a CTR intake cam and jdm gsr exhaust cam (what i have for now)
jdm 4-1 header with a 2.5" collector
skunk2 intake manifold
cai
kenji chipped p28
2.5" exhaust piping
apexi muffler
for what all is going to be on the motor, i don't think i need to go to the extreme on the head work, but i'm thinking that getting the head all polished up won't hurt any.
your thoughts...........
Old Mar 20, 2005 | 12:28 PM
obd2gsr's Avatar
Default Re: do i P&P the head...... (hondaeg8)
do it.
Old Mar 20, 2005 | 12:33 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: do i P&P the head...... (obd2gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr &raquo;</TD></TR><TR><TD CLASS="quote">do it. </TD></TR></TABLE>
Old Mar 20, 2005 | 12:43 PM
strsi's Avatar
Default Re: do i P&P the head...... (DAantagonist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Of course. If it's already off then why not do it?
U can have as much work as u want done, but if ur head cant flow enough to suppport it then ur other work was a waste.
Baddawg1991
24
May 11, 2012 04:52 AM
boostedeghatch
12
May 6, 2005 06:16 PM
MYDA9
May 31, 2004 02:22 PM
project_hatch1.8
Jan 4, 2004 10:53 PM
