need advice Ls/vtec or b16 swap on a DA
Old Mar 20, 2005 | 11:27 AM
91DApwr's Avatar
Default need advice Ls/vtec or b16 swap on a DA
alright i just got a a 91 da a couple months ago i want to do a b16 swap or a do ls/vtec but i want to know anyone who has a ls/vtec now how good does it run does it give u problems and do u drive it on a daily basis
Old Mar 20, 2005 | 12:24 PM
LSvtec03's Avatar
Default Re: need advice Ls/vtec or b16 swap on a DA (nile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nile &raquo;</TD></TR><TR><TD CLASS="quote"> how good does it run does it give u problems and do u drive it on a daily basis</TD></TR></TABLE>
depends...on how half-assed you build it.
Old Mar 20, 2005 | 12:33 PM
Haleiwa-Brando's Avatar
Default Re: need advice Ls/vtec or b16 swap on a DA (LSvtec03)
Before you get bitched at by people, there is a wealth of knowledge to be had by simply using the search button. Google is your friend too
Old Mar 20, 2005 | 09:19 PM
dcRay's Avatar
If you are on a budget, do a b16a swap and vtec all day long. Lsvtec and having the "best of both worlds" doesn't come cheap.
Old Mar 20, 2005 | 09:26 PM
327da9's Avatar
Default Re: need advice Ls/vtec or b16 swap on a DA (dcRay)
The only advice is definitely how much money do you have for parts.
If you have less than $1500 to begin with, i suggest a b16a swap, and building a b18a shortblock on the side. That ways when you have the shortblock built up, you can pull the head off of ur b16 and use that.
91davtec
Oct 27, 2008 06:39 AM
kappa13
Jul 3, 2005 12:29 PM
Altered
Dec 26, 2003 01:14 PM
92TurboLS
Sep 9, 2002 07:32 PM
