Fast Blinkers 05 Si
i have an 05 si... and i want my turn signals to blink fast....i cut the ground wires in the back and it works only in the front...i put them back on....then i cut the front ground wires and it worked in the back but not in the front...anyone know what i can do to make them work right? i think i need a new relay...i really dont wanna spend money on that is so simple but oh well...post back if u can help me out thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si-vtec »</TD></TR><TR><TD CLASS="quote">i have an 05 si... and i want my turn signals to blink fast....i cut the ground wires in the back and it works only in the front...i put them back on....then i cut the front ground wires and it worked in the back but not in the front...anyone know what i can do to make them work right? i think i need a new relay...i really dont wanna spend money on that is so simple but oh well...post back if u can help me out thanx</TD></TR></TABLE>
just dont do it..
just dont do it..
sounds like you have no clue what your doing. usually a rapidly blicking turn signal means either a bulb is blown (on the side which is blinking fast) or there is a short in the wiring.
take it to a shop, DO NOT start cutting wires. That creates a nightmare. And if you don't have a DVOM or know how to use one, then don't even think about doing it yourself. You'll just make it worse.
You should be able to just get an aftermarket relay. They're "illegal" here, only for use by emergency vehicles, but some show cars have them, they can get as fast a strobe or even have syncopated beats. NAPA parts sells them at your own risk.
I do kno what im doing....fast blinkers does not mean u have a blown bulb....it just means i cut a ground wire....to make it blink fast.... ur makin it more complicated than it is....it seems like u dont kno what ur talkin about...at ephatch.com i got the info. quick...i just gotta sotter a relay and cut a wire and ill be done....thanx for the help to everyone else.....
