noise from driver rear side when turning right. wheel bearing???
Old Mar 20, 2005 | 10:32 AM
coot_er's Avatar
Default noise from driver rear side when turning right. wheel bearing???
this is on a 2000 4 dr. it sounds like its grinding. the noise doesn't happen when going straight or turning left. it also goes away when the brakes are pressed. wheel bearing?
Old Mar 21, 2005 | 05:22 AM
JimBlake's Avatar
Default Re: noise from driver rear side when turning right. wheel bearing??? (coot_er)
Could be wheel bearing, check it out. It might be brake pads? After they wear down a little more the warning tabs will start screetching.
Old Mar 21, 2005 | 01:05 PM
honda_kid42's Avatar
i would say wheel bearing...i had the same thing happen to my car and it kept getting worse and made noise all the time after a week or so....
Old Mar 26, 2005 | 08:39 PM
zallenz's Avatar
check for rust buildup on the edges of the rear brake drums, this can cause some noise problems. or if you have discs, check for rust on the pad holders.
Old Mar 27, 2005 | 03:33 AM
SearchBeforeUPost!'s Avatar
Default Re: (zallenz)
make sure the axle nut is tight.
Old Mar 27, 2005 | 06:08 AM
maivietla's Avatar
Default Re: (SearchBeforeUPost!)
I think is ur tire rod, because last time same thing that happened to me. everytime i turned the clicking noise was made.
Old Mar 27, 2005 | 06:10 AM
maivietla's Avatar
Default Re: (maivietla)
yes, it can be ur wheel bearing that also happened to me once, i changed and the grinding noise went away
Old Mar 28, 2005 | 06:30 PM
coot_er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maivietla &raquo;</TD></TR><TR><TD CLASS="quote">yes, it can be ur wheel bearing that also happened to me once, i changed and the grinding noise went away</TD></TR></TABLE>
even if it only happens when NOT braking and turning right simultaneously?
Old Mar 29, 2005 | 03:47 AM
JimBlake's Avatar
Default Re: (coot_er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">even if it only happens when NOT braking and turning right simultaneously?</TD></TR></TABLE>Yes, but also could be brake pads. You can check them both. The brake-pad wear warning tabs do funny things when they're just barely beginning to rub on the rotor.
Tigereye225
Honda Civic (2001 - 2005)
May 15, 2016 03:59 PM
chanelton
Suspension & Brakes
Jun 4, 2010 11:50 AM
91EF_Si
11
Mar 13, 2008 03:45 AM
Mr.Luder
Oct 16, 2007 03:54 PM
Jxi8s2k
Apr 14, 2007 11:22 AM
