Skunk2 Stage 2 & 3 cams
FRANK,
PLEASE SEND ME AN E MAIL, I WANT YOUR RNR COPIES IF YOU STILL HAVE THEM, OR CAN GET AHOLD OF A SET FOR ME..
ILL TAKE A SET OF CAMS TOO IF YOU CAN HOOK IT UP....
LEAVE ME YOUR # OR JUST POST IN HERE CAUSE WHEN I TRY AND SEN E MAIL TO YOU, IT JUST RETURNS IT ... THANKS
Any specs on these? I did a search and didnt find much of anything. If you can provide specs it would be great.
Also are these like the stage1 where you can use them with stock valve springs and retainers. Good question for the racer on a budget!!
Skunk2 cams
Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @ 1mm
Stage II
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage III
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273@ 1mm
Stage I
Stage II
Stage III
frank? are younot seeing my post
i know u were sellin those rims
just let me know if you still have the and want to sell them...
sold them.....
or dont wana get rid of them....
sold them.....
Banned
From: at last finally back to sweet home, sunny north cali, usa
i emailed you at your addy in the profile. i might consider selling them, make me an offer. the tires are BFG G-Force T/A KD's 205/50/15 with 50% tread left. Size is 15x6.5 et 43. With special metal hub centric rings.
Banned
Looking at the Crower spec it *should* be fine with their Eibach springs. But personally I'd only run it with either Skunk2 valve springs or the ITR yellow itr/Portflow inner combo.
right on i cant e mail you back
a couple months ago u wanted 950 ..and imsure the rubber was better
let me know what you will take for them now and we can work somthin out...
if you wanna keep the rubber and just do the rims im cool with that too
just make sure im the first to know when you decide to sell
thanks
thanks
codeh22a4
Mar 5, 2005 04:25 PM
Tofu00
Nov 23, 2004 07:55 AM
Tofu00
Nov 19, 2004 03:37 PM
