Maxpsi's FS thread Mirrors, OEM airbags, machined B16 crank, Domani, injectors, sensor
Will only ship to the continental 48 states. All sales final. Shipping insurance quote upon request and suggested. Prices do not include shipping charge unless specified. Shipped via UPS. Will entertain reasonable offers unless price is listed as "FIRM". If you're viewing this thread, throw a bump my way for a fellow H-T member.
Contact Information:
- Scott
- Email: llamahunter2001@msn.com
- AIM: llamahunter2001
- Located in Alabama
Payment Information:
- Paypal verified (55) @ llamahunter2001@msn.com. PAYPAL INFO
- Money Order (only on orders totaling $75 or less)
- Cashier's Check (only on orders totaling $75 or less)
- Cash (local pick-up only)
*** I WILL SHIP ANYTHING AT BUYERS EXPENSE ***
Check out my excellent feedback on ebay EBAY INFO (62). My name is NOT on the h-t scammers list either H-T SCAMMERS LIST.
67 VOUCHES: -Justin-, 1.8t, Brewer, TurboTegB18c, ShadyEH2, turbotypeR, Civiclx, WIRED RICKY, -JEREMY-, RacerXI, H22PwrdHatch, 30psiCiv, MUteg88, Jspectyper, B18C5_EK, KrautFed, Brian., nuc79, FourDoorTypeR, Disco Monkey, TurbothisLS, sweetcarz02, Ace0246, SpoolFedEF, SloS13, kyden, hondaguyef, Greasemonkey, SERfanatic, FrankencrxBHAM, Tiki_on_Teg, cjohnson_2, Shocka1998LX, dragnGSR, ActiveAero, jp8900, garth, .Stunna., bruceleeroy, Boston, blackccoupe, Lildrgn, graveltravel, EK9 B16B TSL, LSEGHATCH, JDMlifestyle, AURSX-S, 00ITR #543, gardendalegti, Nocturnal, JohnnysEG, Kidd_Stylez, boostFedBrewer, jt2kgsr, .BEN., 95 integra, Laura EP Hatch, ihaterice, automationcivic, bra73d, RedneckDave, Frosty_spl, blaker, inline976, i rock the sohc, honduhkiller, EF8kid
- B16 cams (believe they are from a 99-00 civic Si). Good condition. = $50 OBO
- OEM breather box. A.k.a. the black box that sits on the back of the block and seperates oil vapors. Has a tube running up to the PCV valve. Tube not included
- 1 set (4) of OEM USDM B16 rods with matching caps and cap nuts. Gen 2 rods if that matters. No bearings. Great condition. Hard to tell they are even used.
- oil pressure sending unit
- alternator mounts
- Used GSR OEM open differential. Came from a low mileage transmission. Replaced with new CTR LSD, so I have no need for the open diff anymore.
- Cam seal OEM. Unused still in packaging from Honda. It's the good, rubber, double sided cam seal.
- [b] B16 shortblock. Compression 170 on cylinder 1 dry compression. Great for motor build. Gen 1 block from a del sol. Ran fine until recently replaced with new motor.
- [b] B16 oil pan. Scrapes on bottom, but otherwise in good work order. [b]
- OEM FPR
- OEM battery tie down
- OEM internal coil for B series distributor.
- D15b8 DX transmission
- B16 throttle body with TPS
- Map sensor
- IACV
- [b]Mugen black oil cap. The real thing. Bought from jhpusa.com.
- d1593 cx head
- d15 93 cx shortblock
- d15 distributor
- B16 water tube
- OEM fuel filter
- D15B7 passenger torque mount with nut
- D series flywheel cover
- DX Intake Manifold
- B series aftermarket fuel rail custom painted Tein green
- CX fuel rail with FPR
- OEM B series rear mount with ES insert
- OEM FPR
- B16 EK tranny mount with Prothane insert
- OEM Bseries EK tranny mount bracket
- OEM grey in-cabin fusebox cover with plastic fuse map
- D series oil pan gasket
- D series used OEM flywheel
- B series used OEM flywheel
- D15b8 DX OEM intake manifold with 4 wire O2.
- GSR full length radiator. In working condition. Not the prettiest radiator, but it doesn't leak.
Modified by maxpsi at 9:27 AM 4/2/2007
- Scott
- alternator mounts
- OEM FPR
- Map sensor
- IACV
- d1593 cx head
- d15 distributor
- B16 water tube
- OEM fuel filter
- OEM FPR
dAng!
Somebody buy his stuff, then come to my thread, and buy mine. It would help needy Alabama families.
Bwahahaha! You must be referring to my parachute mount (yes, someone thought that was what it was).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek gripper »</TD></TR><TR><TD CLASS="quote">I looked, free bump</TD></TR></TABLE>
Stop giving me bumps, Jeremy. I'm running out of topical, prescription cream.
