sputtering before vtec...
Old Mar 20, 2005 | 08:06 AM
H22CL's Avatar
Default sputtering before vtec...
just did cams, spring/retainers, and cam gears. since i put everything back together, car sputters and back fires in low rpm (before vtec), in vtec pulls like a bitch. did i forget to connect something? has anyone else experienced this before?
Old Mar 20, 2005 | 08:48 AM
md23vtec's Avatar
Default Re: sputtering before vtec... (H22CL)
Possibly the cam timing is off, it has to be tuned for the cams, got the firing order wrong. Its hard to say but just a few things to check. Hope this helps
Old Mar 20, 2005 | 08:57 AM
H22CL's Avatar
a friend of mines also mentioned the cam timing and said that it would have to be tuned. the firing order is correct.
Old Mar 20, 2005 | 10:35 AM
The Phil's Avatar
Default Re: (H22CL)
ALWAYS tune your car whenever you change something. Especially something like cams/gears/springs/retainers.
EDIT: thought i've seen you here before. for the H22 in your CL.
EmminoDaGreat
Aug 26, 2012 11:02 AM
g4b17
Aug 7, 2012 10:55 AM
91integraLSVTEC
Jan 14, 2009 11:08 AM
dbiker207
Jun 9, 2007 09:02 AM
S9 MECHA KARUMA
Jul 28, 2003 09:16 PM
