scaping sound, not brakes!
Old Mar 20, 2005 | 07:33 AM
Juccord's Avatar
Default scaping sound, not brakes!
I took my car out for the first time after winter 2 days ago, and everything was fine, then yesterday right before I got home, out of nowhere this loud sceeching noise started when I wasnt braking, I tried braking to see if it made a difference but it didnt. im not too sure what the hell it is, but it sounds like the brakes, but its not. its alot louder then ive ever heard with brakes.. Any Ideas?
Old Mar 20, 2005 | 09:02 AM
gwasshoppa911's Avatar
Default Re: scaping sound, not brakes! (Juccord)
I had the same problem on my 6th gen accord. What you need to do is get some new rotors. I did that and the problem was solve instantly. I also changed my brake pads at the same time.
George
http://www.cardomain.com/memberpage/567902
Old Mar 20, 2005 | 12:17 PM
Juccord's Avatar
Default Re: scaping sound, not brakes! (gwasshoppa911)
ya, I just replaced rotors and pads not too long ago, im sure it has nothing to do with the brakes, could it be a blown bearing..? ...again.!
Old Mar 20, 2005 | 01:58 PM
hondaracin24's Avatar
Make sure there not dragging at all.....
Old Mar 21, 2005 | 06:11 AM
Juccord's Avatar
Default Re: scaping sound, not brakes! (hondaracin24)
no, theres nothing draging, im taking it all apart tonight to see if I can figure anything out. thanks though.!
Old Mar 21, 2005 | 06:56 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juccord &raquo;</TD></TR><TR><TD CLASS="quote">ya, I just replaced rotors and pads not too long ago, im sure it has nothing to do with the brakes, could it be a blown bearing..? ...again.!</TD></TR></TABLE>
What pads are you using?
How many miles?
With some aftermarket pads you will hear a metal grinding noise for a while before it disappears i.e. PBR/AXXIS Metal.
Old Mar 21, 2005 | 07:59 AM
SuperSlow's Avatar
are you sure it is not a loose belt?
Old Mar 21, 2005 | 10:07 AM
Juccord's Avatar
Default Re: scaping sound, not brakes! (SuperSlow)
Im using Green stuff pads and brembo OE rotors, ive only put 4000Km on them, its not a belt because it doesnt change at all when I rev it up, just when I start moving. doesnt make a difference if im braking or not, just when im moving. any other ideas?
Old Mar 21, 2005 | 02:59 PM
SuperSlow's Avatar
PS and AC belts will not make more or less noise when you rev it up either.
Check for stones in your wheels.
Old Mar 21, 2005 | 03:16 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">
Check for stones in your wheels.</TD></TR></TABLE>
Stones in the wheels?
Old Mar 21, 2005 | 08:06 PM
SuperSlow's Avatar
Default Re: scaping sound, not brakes! (-Bionic-)
Yeah... like crack cocaine *****!
My boy David with the impreza had some noises coming from his wheel at low speeds and found a small stone inside the wheel rotating assembly...
but in this case, with the 'screeching,' I still bet it is a loose belt.
Old Mar 25, 2005 | 06:52 AM
Juccord's Avatar
HA..!
Ya I feel like a *****.. Took off the wheel and ya, a stone stuck between the dust cover and the rotor, pushing the dust cover against the rotor. put a nice big groove into the back of my rotor.. thanks for your help guys. sorry, I really feel like a sac o'crap
pcguy760
Nov 19, 2007 10:51 PM
the DA in HONDA
Nov 5, 2004 09:52 AM
Lazydsm
Dec 9, 2003 08:35 PM
bhcvc
Jan 14, 2002 07:31 PM
DavidGSR
Aug 17, 2001 04:17 AM
