please help anybody who uses toda spec C's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">no two engines are the same. my settings will not work for you.
take it to a tuner who knows wtf they are doing. and beware valve to piston contact (depending on your build)</TD></TR></TABLE>
Agreed! Headflow, compression, what kind of header or intake manifold all play a role in dialing in cams, what makes power for someone might not make power for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupehybrid »</TD></TR><TR><TD CLASS="quote">+2-1 was not good i tried.i try now -4-4 it looks good for me...</TD></TR></TABLE>
that means that either 1) you have a thicker headgasket or way extra deckheight and head deck that the typical b-series engine (not likely) or 2) your distributor was really advanced and retarding your ign helped ...
I never saw good gains from retarding both cams on any of the Toda A/B/C/D/Killer lines.
If stock motor then try advancing the intake about +2 and leave the exh cam at 0 ... if too much overlap then advance the exh some.
Greg
Greg
allmotaR
12
Feb 23, 2005 03:16 PM
