90 accord electrical problems
ok i know i post this like every weekend but here is goes. When installing the battery on my 90 accord I accidently put the negative on the positive terminal and the positive on the negative terminal. After doing this not realizing that had happend I proceded in starting up the motor but it didn't even make any noise when i turned the key. When i realized what I had done I switched it back but the motor still doesn't even attempt to turn over. The only thing that works is the horn and the hazards. I realize that something is blown I think it is one of the fuses but I am not sure. Ive searched all over for this and no one has done anything as stupid as this. Any advice would be good i need to get this car running by the end of the week so any help is much appreciated.
AIM ME AT:i730nexteldone
You blew the 80 amp black fuse in your engine bay fuse box, 38216-SM4-003. If you replace that and the car still doesn't run then suspect the ECM, but it's unlikely you did any damage asssuming the fuse did its job.
