will a motor perform better if teh ignition timing is advaced all the way? or at a certain timing?
Old Mar 20, 2005 | 05:28 AM
CivicRaping's Avatar
Default will a motor perform better if teh ignition timing is advaced all the way? or at a certain timing?
Old Mar 20, 2005 | 07:33 AM
Targa250R's Avatar
be professional
Default Re: will a motor perform better if teh ignition timing is advaced all the way? or at a certain timin
Depends on the setup.
Old Mar 20, 2005 | 07:56 AM
CRX_Control's Avatar
No , sometimes when you advance it all the way your car will experiece detonation. Mine did this at high rpms during vtec
Old Mar 20, 2005 | 08:39 AM
SilentWrath's Avatar
and sometimes even if you dont get detonation you will gain some low end but sacrifice top end, either set it to factory spec, or get it dynoed
Old Mar 20, 2005 | 09:32 AM
allmotorgsrekk's Avatar
dont be fooled by thinking advancing the timming will make power i just dynoed my car at modacar and advancing the timing didnt make power but by the advice of Casey we started to to take timing and i made power.
Old Mar 20, 2005 | 06:11 PM
leaftye's Avatar
I can't tell you how to find out what it should be, but the maximum pressure in the combustion chamber should occur 14° after top dead center. PM me if you'd like me to post some links about this.
Old Mar 20, 2005 | 06:39 PM
Default Re: (allmotorgsrekk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgsrekk &raquo;</TD></TR><TR><TD CLASS="quote">dont be fooled by thinking advancing the timming will make power i just dynoed my car at modacar and advancing the timing didnt make power but by the advice of Casey we started to to take timing and i made power.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilentWrath &raquo;</TD></TR><TR><TD CLASS="quote"> either set it to factory spec, or get it dynoed</TD></TR></TABLE>
so true, use stock timing or go the the dyno
dsmIA
Jul 12, 2005 08:11 PM
Que_Lude
May 25, 2003 09:45 PM
sharkey65a
Jan 15, 2003 02:07 PM
DLB1994
Aug 27, 2002 12:10 AM
