window moldings / trim
hello all, i did a search but never got a definite answer for what i was looking for,....
When replacing the trim/ window moldings (rear quarter windows and hatch) is the glass encapsulated? Do i need a to purchase the entire window with trim already installed or is it simply separate pieces that can be placed around the window?
Thanks in advance
Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">I believe they are separate pieces.</TD></TR></TABLE>
You my friend, are correct. After you remove the trim, from inside the car, use a knife to cut the adhesive all the way around the glass. Just make sure you dont cut the molding.
