allmotor lsvtec 13.1:1
Old Mar 19, 2005 | 04:17 PM
k24a4kid's Avatar
I'm a Jackass
Default allmotor lsvtec 13.1:1
my set up im doin, planning on running on 94octane .. i would like some poeples opinions and coments
got:
b18a
ctr pistons
gsr head
headstuds
rod bolts
new rod and main bearings
individual throttle bodies
uberdata(2step and datalogin)
skunk2 stage1's
thinkin about:
rocket valve springs and retainers
buddy club cam gears
m24e's or m22??
Modified by turbofienD 04 at 6:02 AM 7/26/2005
Old Mar 19, 2005 | 04:24 PM
SkRiBLaH's Avatar
Default Re: allmotor lsvtec 13.1:1 (turbofienD 04)
go with differant pistons.
like JDM ITRs, or P30's .
heres why:
https://honda-tech.com/zerothread?id=717928
Old Mar 19, 2005 | 04:27 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: allmotor lsvtec 13.1:1 (SkRiBLaH)
yea i read that whole form before, but i still got the ctr's and they are already installed on the rods.. just waiting for bearings and rod bolts
Old Mar 19, 2005 | 05:50 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">go with differant pistons.
heres why:
https://honda-tech.com/zerothread?id=717928</TD></TR></TABLE>
What? I run CTRs with 93 octane and STOCK timing. (Ran on 91 octane back home in AZ when I was there...) No detonation, no pinging... runs great. 190WHP
sander's Avatar
2.7(p/t)
Its kind of a shitty piston design.
If you can get higher compression by using a piston with out as much of a ridicoulus large dome youll make more power....
its about quench
-s
Old Mar 19, 2005 | 05:52 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: allmotor lsvtec 13.1:1 (sander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander &raquo;</TD></TR><TR><TD CLASS="quote">Its kind of a shitty piston design.
its about quench
-s</TD></TR></TABLE> yea i know i shold of got p30's and just shaved the head
Old Mar 19, 2005 | 06:15 PM
UncleD's Avatar
I would only run the BC4's if you're revvin high, and if you're gonna rev high then I wouldn't do the Omni valvetrain. They have a pretty mild spring preasure...big camshafts and high rpm's don't get along real well with a light spring preasure. I would suggest RM gen <U>1's</U> , they have more seat preasure than the gen 2's and will accomadate that cam profile and high high rpms. Good luck man
Old Mar 19, 2005 | 06:26 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: allmotor lsvtec 13.1:1 (clean rice)
i'll tke that into concideration since i didn't order them yet
Old Mar 19, 2005 | 06:43 PM
UncleD's Avatar
Contact Rocket, he's a way cool guy and is <U>VERY</U> honest with his products and even his competition. I believe Tbone runs the gen 1 springs. I know for sure he runs them, just not sure if they are the gen 1 or 2's.
Old Mar 19, 2005 | 06:54 PM
k24a4kid's Avatar
I'm a Jackass
yea i think i might
Old Mar 20, 2005 | 02:56 PM
k24a4kid's Avatar
I'm a Jackass
bump
Old Mar 27, 2005 | 06:02 PM
k24a4kid's Avatar
I'm a Jackass
anybody have any other opinions
Old Mar 28, 2005 | 11:32 AM
EJ1enkeiRSE's Avatar
How are those buddy clubs spec 4 cams? Are they any good? I'm planning to go with the same cams and cam gears. Any info would help thanks.
Old Mar 28, 2005 | 02:00 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: allmotor lsvtec 13.1:1 (EJ1enkeiRSE)
idk yet i'll tell you when i get evrything together and running
Old Mar 28, 2005 | 02:05 PM
ILIKEJDMX999's Avatar
What Trany are u going to use??
Bump, nice set up
Old Mar 29, 2005 | 05:03 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: allmotor lsvtec 13.1:1 (ILIKEJDMX999)
i have gsr laying around so probobly that
Old Mar 31, 2005 | 06:28 PM
k24a4kid's Avatar
I'm a Jackass
i cant decide .. what should i get the m24e's or the m22's? somebody help me out
Old Mar 31, 2005 | 08:18 PM
JDM2ndGen's Avatar
i just PM'ed you ...the M24e's would be good with that compression ...the M22's are a more mild cam ...
Old Mar 31, 2005 | 10:42 PM
UncleD's Avatar
Default Re: allmotor lsvtec 13.1:1 (JDM2ndGen)
I personally would run the M22's. Allot of people underestimate this camshaft. I think people assume that because it's Rocket's smallest cam that it is comparable to a S2S1 or something. They have allot of duration, I have the cams in my room right now and the lobes are wider than my thumb I'm personally building a B16B and since I have the r/s ratio, I wanted a camshaft that would build power high, so i went with the big duration of the M22. My roomate is building a ls/vtec similar to yours and he opted for the S2 Pro 1's because they have allot of lift, but not so much duration. they build power early, so you don't need to rev to the moon to get your power. personally I think the m24e's would be over camming it. Not to say your motor is mild by any means, but M24e's are way way big.....bigger than a BC4 for sure. OH, and BTW.......Tbone runs the RM gen 2 springs, so that tells you right there how well designed and made they are!
Old Apr 1, 2005 | 04:22 AM
k24a4kid's Avatar
I'm a Jackass
pm sent ....
yea i noticed they are bigger than everything almost.. and i dont really mind reving high to get power.. at first i wanted to go with the m25 cuase ihtough bigger was beter but not really with thses cams, i didn't kow how big they really were till i seen them read about them some... for the next build im deffenetly using the m25e's ...yea it was either the rocket springs and retainers or the rm gen 2's so idk yet, i was looking in to the omni at first but i think they're to soft for these cams....
Old Apr 1, 2005 | 03:23 PM
k24a4kid's Avatar
I'm a Jackass
anymore opinions??
Old Apr 1, 2005 | 03:47 PM
JDM2ndGen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I personally would run the M22's. Allot of people underestimate this camshaft. I think people assume that because it's Rocket's smallest cam that it is comparable to a S2S1 or something. They have allot of duration, I have the cams in my room right now and the lobes are wider than my thumb I'm personally building a B16B and since I have the r/s ratio, I wanted a camshaft that would build power high, so i went with the big duration of the M22. My roomate is building a ls/vtec similar to yours and he opted for the S2 Pro 1's because they have allot of lift, but not so much duration. they build power early, so you don't need to rev to the moon to get your power. personally I think the m24e's would be over camming it. Not to say your motor is mild by any means, but M24e's are way way big.....bigger than a BC4 for sure. OH, and BTW.......Tbone runs the RM gen 2 springs, so that tells you right there how well designed and made they are! </TD></TR></TABLE>i dont think they are over camming it at all ...when i was going to buld my 13.5:1 B series ...from talking to rocket he actaully recommended the M24x's which are bigger than the M24e's ... Tbone when he had 13.5:1 comp. he dyno'ed the M24e's and put down 230WHP ...and with the Sks3's i think if i remember correctly he put down 238WHP im not positive ...i asked rocket about the m25 and the M25e's and he said the compression you would need to get the max power out of them would be somewhere in the area of 14 to 15+ comp. ... but talk to rocket he is the one that knows whats best and he can put you on the right path ...
Modified by JDM2ndGen at 7:48 PM 4/1/2005
Old Apr 1, 2005 | 06:09 PM
k24a4kid's Avatar
I'm a Jackass
i did take to him already but idk now... i'll see
Old Jul 26, 2005 | 01:59 AM
k24a4kid's Avatar
I'm a Jackass
im on vacatiopn and was bored and looked up some old topics... i got the motor together and with some skunk 2 stage 1's only becuase i got them for dirt cheap.. i got some pics on my computer so i'll post them up of how it looks when i come back..i got diy itb's but i think they are too small for this setup.. they arent one yet ...
dc2JDMwhore
May 12, 2014 02:57 PM
jspec-integ Ls
Northwest (Sales)
Jun 1, 2008 11:06 PM
CivicVX94
Sep 2, 2006 10:49 PM
egvtec
Dec 12, 2005 03:49 PM
Dirtfall
Sep 16, 2005 08:21 AM
