Is my timing belt too loose? *video*
Old Mar 19, 2005 | 11:48 AM
RTW DC2R's Avatar
Default Is my timing belt too loose? *video*
In the process of inspecting my new motor after about 1000 break in miles. Timing belt looks like it might be a tad loose, but I dont have anything to compare it to. Im running a 2 layer gasket so I cant just tighten the tensioner to stock. Its definitely a bit more loose than when I first installed it, which I guess is to be expected, but Im not sure if its too loose.
short vid: right click, save as http://www.we-todd-did-racing....DE%3D
Old Mar 19, 2005 | 11:59 AM
92TypeR's Avatar
FSAE
Default Re: Is my timing belt too loose? *video* (RTW Ryan)
Looks to be about a half-inch deflection, +/- a little.
If you are running cams with large primaries, ie: Toda B/C, you might want to try to tighten it a little more, just as an extra precaution against the belt skipping a tooth.
Old Mar 19, 2005 | 04:04 PM
mingbling96's Avatar
the part from the exhaust cam to the crank pulley's tension varies depending on where the engine is at relative to tdc. check to see if the tension between yr cam gears are tight.. that tension won't change. If you are in any doubt, its easy to retension the timing belt.. regardless you should do it anyways.
EM1Guru
18
Feb 13, 2010 04:02 PM
lopey
Jul 10, 2008 11:11 AM
RCautoworks
25
Aug 15, 2004 09:17 PM
DIYMIKE
Mar 10, 2004 06:48 PM
