questions about a d16y7 in a crx hf
ok i have a crx hf i just got a y7 for really cheap
i have a few questions about this setup
1. can i use a A6 intake and ex manifolds so i dont have to convert to odb2? and use the A6 ECU?
2. can i use a 91 si tranny on this motor? if so what do i need if anything?
3. i can get a b16 stroker kit fairly cheap it makes a b16 a 2.0 is there any way to use this in the d16 to make it a 2.0?
any help would be super cool
TIA
TIA
1. Yes you can use the A6 IM and EM and a6 ecu on the y7. d16 parts are all interchangeable.
2. Yes. Basically all you need is another person because its a bitch swapping in trannies yourself. A helms manual helps, but its pretty straightforward.
3. No
3. No
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egOt »</TD></TR><TR><TD CLASS="quote">1. Yes you can use the A6 IM and EM and a6 ecu on the y7. d16 parts are all interchangeable.
3. No</TD></TR></TABLE>
Thanks for the info
about # three....the block cant macined to fit the pistions,rods and crank?
Thanks for the info
#3......no way man, the d series bore is only 75mm vs the 81mm bore of the b16. yes they are both 1.6L but one is due to bore(b16) and the other is due to stroke(d16).......the crank would not work at all, and the stroker b16 rods would probably be around the same length as the stock d16 rods, and the pistons for the kit would probably be around 83+mm which i really dont think you can even sleeve a 75mm stock bore to 83mm........best of luck man
Braco11
Sep 6, 2005 02:37 PM
wannab20hatch
13
Mar 18, 2003 02:46 PM
