Engine Problem
Old Jan 24, 2002 | 12:05 PM
slowestcivicever's Avatar
Default Engine Problem
I need some help troubleshooting my car...this is what happened...i was driving my car kind of hard right after i swapped my engine which is an 98 civic ex manual engine...i came up to a red light so i had to come to a complete stop...then i tried to take off again and right when i started taking off the engine jerked a little and it died out...i tried to start it off again and it didnt want to start...it cranks and everything...sometimes it wants to start then it dies out...whats my problem?...is it because of my timing belt breaking or something?...let me know whats up please
Old Jan 24, 2002 | 12:22 PM
mercury's Avatar
New User
Default Re: Engine Problem (slowestcivicever)
air, fuel, spark.
Barring a hamster getting sucked up into your throttle body, it's probably not an air problem.
I'd check for fuel and spark. Because this is a pretty fresh swap, I'd reckon some connection may be loose. Check all your connections!
Old Jan 24, 2002 | 01:59 PM
Default Re: Engine Problem (mercury)
i tried using starting fluid but it didnt help...hopes this information helps a little
Old Jan 24, 2002 | 04:13 PM
976's Avatar
976
New User
Come one, something easier....
Alternator!
Old Jan 26, 2002 | 05:15 PM
SiViK-R's Avatar
Default Re: Engine Problem (B21A)
how can the alternator cause the car to crank but not run?
Old Jan 26, 2002 | 05:52 PM
brian j's Avatar
Default Re: Engine Problem (SiViKbOi)
i would first check all your belts then check for spark....its prolly an ignition problem.
Old Jan 26, 2002 | 06:30 PM
fixhondas's Avatar
Default Re: Engine Problem (brian j)
do you have spark??? what's the mileage on your ride? Any "tune ups" that did not use Honda parts??
Old Jan 26, 2002 | 07:04 PM
Default Re: Engine Problem (fixhondas)
I dont any spark...i only have about 67,000 miles on it...i didnt tune up anything i just added intake and headers. help me please.
Old Jan 26, 2002 | 07:10 PM
fixhondas's Avatar
so - with a plug wire unhooked and spark plug inserted and grounded and cranking you have no spark? Any check engine light?
Old Jan 26, 2002 | 07:13 PM
No spark at all. didnt check for the engine light. ill do that tommorrow. anything i should know before i go work on my car?
Old Jan 26, 2002 | 07:14 PM
fixhondas's Avatar
if you have no spark do this-
remove the distributor cap and rotor
find the negative terminal on the coil
use a test light hooked up to the battery positive and coil negative and check for pulsing light during crank
Old Jan 26, 2002 | 07:23 PM
what should i do if there is a pulse and if there isnt one?
Old Jan 26, 2002 | 07:44 PM
fixhondas's Avatar
if there is a pulse- then your coil is PROBABLY burned up and needs replaced-to double check- put a plug wire in the end of the coil and hook it to a spark plug that is grounded and crank to see if there is spark - sometimes the rotor will send spark to the distributor shaft and not to the cap- if the coil is burned out then your cap, rotor, and plugs should be replaced at the same time- when these items wear out they cause extra strain on the coil. If you have spark from the coil- try a new cap and rotor and plugs. Use only Honda parts.
Old Jan 26, 2002 | 10:53 PM
alright...thanks for the information
Old Jan 27, 2002 | 02:56 PM
Hey I swapped out the whole distributor and rotor and tried to crank it for a minute with the gas pedal down and it still does not work...what should i do?
Old Jan 27, 2002 | 04:48 PM
976's Avatar
976
New User
Did you put your wires to the correct cylinders? Many people put them on backwards, such as cylinder #1 from distributor to cylinder #4.
Old Jan 28, 2002 | 07:28 AM
Yes I did and it still does not want to start running
Old Jan 28, 2002 | 01:14 PM
97VTi's Avatar
ignition module, maybe??
Old Jan 28, 2002 | 01:40 PM
Gennady's Avatar
New User
I'm thinking fuel pump. Sounds simple right? It cranks but doesnt turn over. But that doesnt account for the spark issue. But check the fuel pump anyway. If all else fails, reset your ECU.
Old Jan 28, 2002 | 02:28 PM
Default Re: Engine Problem (Wont be beat)
Changed the fuel pump and still nothing...where is the ignition module located?...ill try putting a new one.
Old Jan 28, 2002 | 02:37 PM
Gennady's Avatar
New User
Try the ECU. Resetting it cant hurt. I'm not sure how though. That was the problem I had after I shorted a wire.
Old Jan 28, 2002 | 03:27 PM
fixhondas's Avatar
do you have spark? do you have fuel pressure?
Old Jan 28, 2002 | 04:57 PM
97VTi's Avatar
I had an accord that did the samething. Replaced the ignition module and it worked fine. Its the small silver rectangle box in the engine compartment. Not sure if the civic has an external one... See if there is anything in the manual.
Old Jan 29, 2002 | 04:58 AM
i dont have spark but i had fuel pumping...
Old Jan 29, 2002 | 11:48 AM
fixhondas's Avatar
Igniter is in the distributor- didn't you swap out the distributor? If you did swap- did you have to put your igniter in it? Check for pulsing ground at the coil negative terminal while cranking.
