84.5MM New LS Block For Sale. So. CA.
ah good questions.
it has been resleeved. if you look at the block to sleeve clearance you can see that these are some thicker sleeves than oem. it has been resleeved to 84.5mm and has not yet been run so the block and sleeves are fresh.
it was sleeved by ac auto machines. head machinist worked for rs motorworks then opened his own shop.
Modified by tunedek at 10:07 PM 3/24/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedek »</TD></TR><TR><TD CLASS="quote">it was sleeved by ac auto machines. head machinist worked for rs motorworks then opened his own shop. sleeves are constructed out of solid chuncks of stalk alumminum.
aluminum sleeves? i prefer ductile iron sleeves myself...hehe
what kind of warranty did they give you on it?
</TD></TR></TABLE>aluminum sleeves? i prefer ductile iron sleeves myself...hehe
* B A N N E D *
Aluminum sleeves?
So what happens when you start it up w/ some nice CP's in them.
Turns back into big chunks of 'stalk aluminum.' LOL
Can't run aluminum sleeves unless you're running IRON pistons.
Modified by Vita-Soy at 12:57 PM 3/24/2005
</TD></TR></TABLE>Aluminum sleeves?
I'm pretty sure they are made of aluminum cause it has sat in my garage for over a week now and it does not have any rust on the sleeve and aluminum doesn't rust. I don't know about that piston comment you made though. That doesn't make sense 'casue I have run his blocks before without a problem. I have never run CP's. Only Weiscos but they aren't made of iron.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vita-Soy »</TD></TR><TR><TD CLASS="quote">
Aluminum sleeves?
Modified by Vita-Soy at 12:57 PM 3/24/2005</TD></TR></TABLE>
Think about this man. Honda motors have alumminum sleeves. That just doesn't add up in my add?
Anyways bump for a good block and sleeves
Aluminum sleeves?
* B A N N E D *
ARE YOU KIDDING ME?!?!?!
They're aluminum outer and the inner portion of the sleeve the ACTUAL CYLINDER is IRON... <FONT SIZE="3">Its not adding up for you b/c you have the MATH all WRONG</FONT>
Just incase you need a pic....
</TD></TR></TABLE>ARE YOU KIDDING ME?!?!?!
Soy bean,
Ok you are right. After doing research you are right but I was wrong on two points. The first being your point and the second being the material of the block. I called the machinist. I thought it was alumminum - it's not. I tested it by putting a magnet to the block. It stuck to the sleeves. It is a an iron sleeve.
Good **** learn stuff each day.
Modified by tunedek at 5:42 PM 3/25/2005
Good **** learn stuff each day.Modified by tunedek at 5:42 PM 3/25/2005
saw the block its a grade A block!!! i picked up the b18c off you! man i want this block sooooo bad!!! but that night i blew my headgasket =\ hey btw hit me up for those papers on my cell pm me for the number
lol. sorry to hear that the head gasket popped. ya man tell your friends i wanna sell this. sounds like the b18c went well for you. fax those papers over to 8056421300. ill message you to confirm i got them because sometimes the fax here sux. thanks. matt.
