84.5MM LS Block For Sale. So. CA.
All the machine work was done my AC Automotive Machines. They do most of the local work here. They are a good shop. Mostly Honda stuff (that is what runs around here) but some V8's too. Head machinist used to work for RS Motorworks then opened his shop with his brother.
Modified by tunedek at 12:16 PM 3/19/2005
I went out to my garage and examined that for you. I was sure of this but wanted to double check before I sell anything. I measured it and re-examined the block. The sleeves are not offset. They are dead on. However in the photo it appears to be offset because of that corner ... it is the cut of the sleeve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedek »</TD></TR><TR><TD CLASS="quote">This block includes the mains, sleeves and block. I am asking $800. Also interested in: a set of Rota Slips (black) with or without tires, direct port nitrious kit, regualr nitrious kit (wet only on nitrious kit) and also looking for turbo kit.
What kind of sleeves?
</TD></TR></TABLE>What kind of sleeves?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2integra2001 »</TD></TR><TR><TD CLASS="quote">those are some nice sleeves..do you think that the wiseco 84mm pistons could fit in this nicely? </TD></TR></TABLE>
hey they are nice sleeves. hum well im not an expert. trying doing a little research but i think that 84mm would be too small. the bore is 84.5mm and motors a pretty precise machines but .5mm is a small difference. hey wait ... i think 84mm would work but please research it first. thanks.
I talked to my friend Chris just now. He said he also lives in N Las Vegas off of the 215 and Losse. Email me tunedek@yahoo.com or AIM tunedctr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb »</TD></TR><TR><TD CLASS="quote">sent you a pm</TD></TR></TABLE>
you send me an aim. just call my phone or aim me again cause i lost your SN. thanks
matt 8054431686
matt 8054431686
Soy bean,
Ok you are right. After doing research you are right but I was wrong on two points. The first being your point and the second being the material of the block. I called the machinist. I thought it was alumminum - it's not. I tested it by putting a magnet to the block. It stuck to the sleeves. It is a an iron sleeve.
Good **** learn stuff each day.
Modified by tunedek at 5:42 PM 3/25/2005
Good **** learn stuff each day.Modified by tunedek at 5:42 PM 3/25/2005
