P30 Pistons on LS question
Old Mar 18, 2005 | 07:37 PM
r3v da t3g's Avatar
Default P30 Pistons on LS question
I read through the archives about p30 pistons. Im rebuilding my ls and thinking of purchasing p30 pistons, the info i got is that it would raise my compression to 11:1.
Would it be alright to use stock rods, gaskets with no problems for daily driving?
Would it be necessary to honed the block? Last insite is that im going to get p30 pistons, ARP rod bolts, valve springs and retainers. ? ??
Old Mar 18, 2005 | 07:46 PM
Kendall's Avatar
Stock rods, seals, gaskets, etc will all be fine, but do invest in the ARP rod bolts.
And yes, get the block honed.
Old Mar 18, 2005 | 08:32 PM
projectTeG's Avatar
hey sry for the thread steal, but im doing the same thing and i was wondering if you shot peened the rods and got arp rod bolt what could you rev the ls to with springs and retainers?
Old Mar 18, 2005 | 08:46 PM
Kendall's Avatar
Shotpeening the rods won't safely increase the revving capability of the motor. In order to do so properly, have it balanced. Plus the stock cams are rather anemic at high engine speeds anyway, so plan on cams and springs at the least.
Old Mar 18, 2005 | 08:52 PM
r3v da t3g's Avatar
Default Re: (Kendall)
So i shouldnt replace the gaskets, rods,seals, etc...? All that needs to be done is get the block honed and ARP rod bolts? i have already gotten my gaskets and seals replaced about at 150k but the valve springs and retainers have 160+k on it should i replace it ?
Old Mar 18, 2005 | 08:58 PM
Kendall's Avatar
Default Re: (r3v da t3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">So i shouldnt replace the gaskets, rods,seals, etc...? All that needs to be done is get the block honed and ARP rod bolts? i have already gotten my gaskets and seals replaced about at 150k but the valve springs and retainers have 160+k on it should i replace it ? </TD></TR></TABLE>
Yes, replace the gaskets, seals, etc. I was just stating that OEM (also known as "stock") parts will be fine.
Old Mar 18, 2005 | 09:02 PM
r3v da t3g's Avatar
Thanks for the info, time to get them now!! and install them suckers.
Old Mar 26, 2005 | 08:06 AM
rEGan's Avatar
I'm going with p30 pistons and Crower 404's w/ matching dual valve springs and titanium retainers
good luck on your setup, make sure you have the car tuned, makes a world of difference.
unusual71
14
Feb 6, 2014 10:22 PM
LS-turboner
Jan 8, 2010 04:25 PM
djickabod
14
Dec 22, 2009 04:53 PM
anrkii
Sep 5, 2007 05:06 PM
LSVTEC 91 Civic
30
Mar 29, 2005 05:40 PM
