Let's see pics of a *cleanly done* B16 swap - no hacks please
Old Mar 18, 2005 | 12:13 PM
maxt's Avatar
Default Let's see pics of a *cleanly done* B16 swap - no hacks please
I recently purchased my first EF (been wanting one for a long time!). It's a DX trim with 151k miles on the odometer, but it is very clean in and out except for a little rust on the passenger side rocker panel. I have molested cars in the past and I swore to myself Im not going to molest this little EF, since its still all OEM and so nice.
I've added a few SI upgrades (pass side mirror, tach, clock) but im thinking that the d15 will definitely have to go eventually and that the B16 will go in. One thing im concerned about, is to keep the car OEM looking both from the outside and in the engine bay.
So, is it possible to get a B16 installed into an EF and NOT have an engine bay that looks hacked up (I've seen plenty of B16 swaps with wiring all over the place, cheap looking intakes, etc). Is there a stock intake that will work with the B16 manifold?
Another question I have, is about the engine mount set...I understand some engine mounts need to be changed in order to mount the B series motor into the D series engine bay - so is there a set of mounts that are NOT super rock hard poly urethane and wont rattle my teeth out?
my newly acquired DX:
Old Mar 18, 2005 | 12:25 PM
Magick211's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (maxt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Here is mine with all the headlight wiring hidden in the frame rail. And the underhood fuse box has been relocated.</TD></TR></TABLE>
Old Mar 18, 2005 | 12:29 PM
Don's Avatar
Don
New User
This is mine. I kept all OEM wiring and tubes I didn't remove anything. I attached the 5 wire subharness to the big one. My only problem was that the hood rubbed a bit on the engine... I had to shim it down a tad. All I did for the intake was use the B16 intake and attached it to the OEM one. As for mounts I used the HCP 1st gen but never again... I just didn't like it.
Old Mar 18, 2005 | 12:30 PM
maxt's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (Don)
what mounts are you guys using now? too soft or too hard? I've had full polyurethane mounts before, never again
I like your bay Don. OEM looking = good.
Old Mar 18, 2005 | 12:31 PM
slowpokesi's Avatar
my swap is clean, and is not a hack job by any means.
all of my wiring is saudered, and loomed and zipped into place.
Old Mar 18, 2005 | 12:35 PM
Don's Avatar
Don
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxt &raquo;</TD></TR><TR><TD CLASS="quote">what mounts are you guys using now? too soft or too hard? I've had full polyurethane mounts before, never again
I like your bay Don. OEM looking = good.</TD></TR></TABLE>
Thanks, I didn't change the mounts as the car was stolen 1 month after these pics were taken (My old CRX Si SE). I also want something stock feeling but am unsure as to what I should put... I'm actually thinking of modifiying the monuts by welding them in for my new B series in the new car but... I am not sure... I'd prefer 4 mounts like the OEM...
Modified by Don at 1:45 PM 3/18/2005
Old Mar 18, 2005 | 12:42 PM
CRX Toad's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (Magick211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">
BTW I STILL HATE YOU FOR THIS!
Old Mar 18, 2005 | 12:49 PM
Malgerus's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (CRX Toad)
Here's mine.
I don't have a stock intake, but I think the install was overall very clean:
Old Mar 18, 2005 | 12:53 PM
Saki's Avatar
Heres mine... Its FOR SALE too https://honda-tech.com/zerothread?id=1178612
Old Mar 18, 2005 | 12:56 PM
Stefndogg's Avatar
old pic but u get the idea
Old Mar 18, 2005 | 02:00 PM
quik89's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (Stefndogg)
here's my old car swapped, 4 door, not completely clean, but not to horrible either....
Old Mar 18, 2005 | 02:02 PM
Magick211's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (quik89)
Here ill post another one. This one is not mine but its clean
Old Mar 18, 2005 | 02:05 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Here ill post another one. This one is not mine but its clean
DAMN I hope I can get mine that clean
Old Mar 18, 2005 | 02:10 PM
insomniac791's Avatar
Magick211 - NICE BAy the owner took some time on that one
Old Mar 18, 2005 | 02:18 PM
Magick211's Avatar
Default Re: (insomniac791)
Yeah thats what im trying to do on mine as you can see on my erlier post. i have all the wriing hidden and my fuse box is inside by the ecu
Old Mar 18, 2005 | 02:42 PM
kid-honda's Avatar
Old Mar 18, 2005 | 02:51 PM
quik89's Avatar
those look f**%kin good!!!!! damn...
Old Mar 18, 2005 | 02:58 PM
ELAMINT5's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (kid-honda)
the last two are extremely clean and yes, yours is to Magick211, but taking the charcoal canister out just seems dangerous to me. Plus I have heard that it puts off a gas smell. Why do you do this if it is dangerous? I mean it is clean as FU*K I wish I would but I worry about it. Have any of you noticed a gas smell if no what did you do to get around it? I want my bay area that clean. Clean enough to at on!
Old Mar 18, 2005 | 03:33 PM
kid-honda's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (ELAMINT5)
I got no gas smell, its just a vent tube and you can put it under the car.
Old Mar 18, 2005 | 03:44 PM
Scantron's Avatar
Hey where do you guys hide all the wiring and all the extras?? Fuse box where the ECU is,but where is the rest of it.. Looks like a project i mite start
Old Mar 18, 2005 | 03:45 PM
ELAMINT5's Avatar
did you extend it? where do you have it at? aren't you worried the gas vapors will ignite?
Old Mar 18, 2005 | 03:53 PM
RickyGoshDarn's Avatar
Mine but don't have a stock intake
Old Mar 18, 2005 | 05:38 PM
GSRCRXsi's Avatar
Old Mar 18, 2005 | 06:13 PM
maxt's Avatar
Default Re: (GSRCRXsi)
Nice
Im seeing a lot of super clean swaps. THanks for the pics
Old Mar 18, 2005 | 06:49 PM
jdmjunky's Avatar
Default Re: Let's see pics of a *cleanly done* B16 swap - no hacks please (CrxWolf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrxWolf &raquo;</TD></TR><TR><TD CLASS="quote">Mine but don't have a stock intake
this one and the white one fooo shoooo
